Old 08-30-2017, 02:46 PM
[email protected] pqlior@mac.com is offline
Default Presets for 'import session data' elements
I do a lot of session data import when I switch to a new mix using that terrible pull-down menu to select different options, which is cumbersome.
I'd like to set presets for elements I often use, (similar to window configuration) and be able to pull that up instantly.
It's up on ideascale:
http://protools.ideascale.com/a/idea-v2/279569
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 08-30-2017, 03:20 PM
Drew Mazurek's Avatar
Default Re: Presets for 'import session data' elements
A long time request.
Avid is aware and it's in the queue.
www.drewmazurek.com
Old 08-30-2017, 04:02 PM
Awesome! Let's bring it!
Lior
Old 11-10-2021, 09:24 AM
schoen schoen is offline
did someting happen concerning this topic?
Old 11-11-2021, 01:15 AM
... I Import Track data frequently, but I want to "link to source media" - every time I have to change the "audio media option" because there is another default value.
No chance to change the settings :-(
Had to create a workaround by soundflow, see attached...
File Type: jpg Bildschirmfoto 2021-11-11 um 10.10.14.jpg (25.0 KB, 0 views)
Pro Tools 9 crashes every time I open a new session or import session data Ryan Butler macOS 14 03-23-2014 07:53 AM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
End of Stream Reached - session broken - import session data does not work... Sean Russell Pro Tools TDM Systems (Mac) 0 01-15-2010 04:56 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
