Old 06-02-2014, 07:46 AM
Tnrocks Tnrocks is offline
Default Help with connecting eleven rack to g-system
So first off I'm not sure if this is possible but what I want to do is connect my 11r to my 5150 III 50w and then to the G system. First thing is I am using the fx loop of the 5150 to connect it to the G system with the 4cm. I would need to somehow send power to the 11r and connect it to a loop in the g system, sort of treating the 11r like an effects pedal or another amp?
I then can connect the midi of the 11r to the g system for preset switching. Can someone explain how this can be done?
Old 06-03-2014, 07:56 AM
DonaldR DonaldR is offline
Default Re: Help with connecting eleven rack to g-system
I assume that should work:
Guitar -> Gsys input -> Gsys send -> 11R input -> 11R send -> 5150 input -> 5150 send -> 11R return -> 11R amp2 -> Gsys return -> Gsys output -> 5150 return
You should be able to set Gsys and 11R effect loops wherever you want per preset.
Old 06-03-2014, 11:28 AM
Thanks for the help. That seems to be working great. The only thing I am stumped over is all the knobs on my 5150 aren't doing anything at all. No clue why
Old 06-03-2014, 12:15 PM
Should be the case when you "bypass" 5150 input in your preset depending on where you place Gsys/11R effect loop.
Old 06-03-2014, 03:58 PM
The problem was the fx loop in the chain the mix was set to 50% when at 100% it's the EVH tone and controls. There is also a send and return level on the fx loop, should I set that to 0db? I have tone loss and some white noise.
My rig input is set to guitar.
Fx loop is routing mono (L)
Digital outputs: Rig Output
Outputs to amp signal: Rig no cab
Thanks for the help!
ELEVEN RACK and G-SYSTEM reycantong Eleven Rack 6 01-11-2015 01:13 PM
Eleven Rack and System Audio Breasal09 Eleven Rack 19 02-28-2014 04:13 AM
Connecting Rme Babyface And Eleven Rack Digitally kimballob Eleven Rack 0 09-02-2013 10:50 AM
Connecting GR-55 to Eleven Rack Troubleshoot mrsirjmiller Eleven Rack 1 08-18-2013 05:41 PM
Connecting Eleven Rack to Digi 002 Rack TMitchJobe Eleven Rack 12 02-02-2013 10:54 AM
