New Build w/ Older Rack
I recently built AMD Ryzen 5 3400G w/ Aesus X570 MB, Windows 10, wanted to add Firewire PCIe to interface 003 Rack + (LE 8.05) but after researching it looks like this hardware isn't even supported anymore. Can I update Pro Tools ?(Not sure how or if it is even compatible with Windows 10.) Admittedly I haven't been involved for years, but pertinent info doesn't seem easily deciphered, and I can't say Avid is exactly chomping at the bit for person to person help. Any info about my options would be appreciated.
Re: New Build w/ Older Rack
You can take a look at the Pro Tools Operating System Compatibility Chart to see which versions of Pro Tools are compatible with which OS version.
Here is a link to the Pro Tools System Requirements as well. Hope that helps and please ask any other questions you may have about compatibility. |
The odds of the 003rack working are actually pretty good. But you will need newer PT software. IIRC, 12.4 or 12.5 is the first version to be compatible with Windows 10.
I'm still on v11.3.2 (The last version before subscription model) and whilst not 'officially' compatible, it works fine on Win10.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Older 11 rack and newer version | Sam C | Eleven Rack | 6 | 04-02-2013 07:37 PM |
003 rack comp build. Need some info... | geekkiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-18-2010 02:32 PM |
003 Rack - Windows 7 - New Build | lowlights | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-13-2009 03:03 PM |
Possible i5 Build for PT LE 8.0.1 / 003 Rack | lowlights | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-13-2009 02:44 PM |
Build your own isolation rack case? | bwherry | General Discussion | 7 | 11-28-2003 11:18 PM |
