Old 05-22-2023, 02:00 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Does anyone actually have an XMON working with a Dock and Avid Control?
I have spent all of an 8 hour day trying to get an original Digidesign XMON to work with my new S1/Dock setup.
I have purchased a breakout cable that seems to be wired correctly. I have tried 2 different USB interfaces, countless cables, wiped and reinstalled software and no love.
If there is anyone who actually has this setup working please help!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 05-22-2023, 02:39 PM
BScout BScout is offline
Default Re: Does anyone actually have an XMON working with a Dock and Avid Control?
So does the Xmon software recognize and work with it? The communication goes:
Hardware Xmon <> serial protocol to USB <> Xmon software <> Eucon <> Eucontrol/WSControl
Just trying to figure out where you have a break in the communication.
I had an Xmon working with an S6 for quite a while (which is the same up to the Eucontrol vs WSControl above.)
But one thing I remember is that Avid were really insistent on replacing our Xmon (which was originally a Digidesign branded one that was part of our Icon setup) and it was swapped to an Avid branded one with the S6. Never got a solid answer whether that was actually required (or everyone just wanted to update everything as a package.)
Old 05-22-2023, 03:08 PM
Hi and thanks for offering your help!
Before I started down this road I was assured by senior Avid people that this combination would work with the proper breakout cable.
I purchased a DB 15 to midi break out cable on eBay. I double checked the wiring with a wiring diagram that I got and wiring is correct.
My blue Digidesign XMON was working perfectly with my D-Command on Sunday.
My Dock/Control app sees and communicates with the XMON app.
The XMON app acknowledges the MIDI interface.
So the problem is somewhere between the midi interface and the XMON.
I have tried two different midi interfaces so it's unlikely that the interface is the issue.
Will Russell
Old 05-22-2023, 06:40 PM
any chance you have messages blocked/filtered in Audio MIDI Setup? We used a MIO midi device for this when we had it running.
(I'm speaking in past tense because after a year we switched that room to MTRX/DADman so I'm doing this from memory)
Old 05-22-2023, 08:32 PM
smurfyou smurfyou is offline
First thing is to check the cables:
Interface MIDI Out -> XMON MIDI In
and
Interface MIDI In -> XMon MIDI Out.
And it sounds like you've right-clicked on the Xmon icon and selected the correct device & port?
Have you removed that MIDI Interface from Pro Tools' "MIDI Input Devices"?
~Will
Old 05-23-2023, 03:12 AM
I will check!
Will Russell
Old 05-23-2023, 03:16 AM
and
I do believe that I have the MIDI cables correctly connected.
I have the proper device and port selected. The XMON app sees the interface and if I move a fader on the XMON app I see MIDI data indicated on the MIDI interface.
Pro Tools isn't even open when I'm testing this but I can check to see if the MIDI interface is still "removed"
Will Russell
Old 05-23-2023, 07:16 AM
Not sure if you can see your Xmon from mix position but if so does the MIDI activity light show anything?
Is this a custom built cable you bought? Nevermind you say you tested the pins...
~Will
Old 05-23-2023, 08:14 AM
EddieJones's Avatar
You probably already have this but in case. http://akmedia.digidesign.com/suppor...uide_83535.pdf Pin out is in there. FYI we sold over 1000 XMON EUCON kits so we know it works
Old 05-23-2023, 12:09 PM
Is Mio a brand?
like this?
https://www.iconnectivity.com/products/midi/mio
Will Russell
Avid control and avid dock softkey issue Lcepeda Avid S1, S3, Dock and Control App 1 12-06-2022 08:22 AM
Connection problems/IP issues? with Avid Control and Avid Dock Voldemort Avid S1, S3, Dock and Control App 6 10-25-2022 02:35 AM
FS: 2 Avid S1 Control Surface and Avid Dock, including 2 Samsung S6 tablets Imagine Buy & Sell 2 10-05-2022 04:03 PM
Ex MC Control/Artist Control users and now AVID Dock User. Questions Zak7 Avid S1, S3, Dock and Control App 8 03-11-2021 11:30 AM
