Old 05-15-2023, 10:04 AM
captainvimmes captainvimmes is offline
Default Display Module on VESA arm
Hi all,
I had an idea recently to try and mount the Display module we use for the PPM on a VESA mount so we can easily position it in/out of vision without blocking the main computer screens. Hs anyone done this? I imagine the hardest things will be the power source... is there an easy way to extend the very short cable currently providing power to the display?
VESA arm example:
Many thanks
Alex
Old 05-16-2023, 07:43 AM
EddieJones's Avatar
Default Re: Display Module on VESA arm
Its just 12v. Make sure you get the polarity correct
Old 05-22-2023, 11:38 AM
lucienpalmer lucienpalmer is offline
I had success doing this using an iPad gooseneck stand that clamps on the the desk. I just cut off the excess plastic on the mount and drilled holes corresponding with the screw holes on the display.
FYI, the longest power cable in the bundle, had plenty of room to reach the input on the display.
I’ll see if I can find an old photo. I don’t currently have it set up that way.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 05-26-2023, 02:23 AM
Thanks both!
How to connect my computer to S4 display module? kinghand Avid S4/S6 7 12-02-2022 05:48 AM
Post Display Module setup lucienpalmer Avid S4/S6 5 12-12-2021 01:14 PM
Fader Module meter led display with 5.1 tracks o-matic Avid S4/S6 13 08-27-2021 08:17 AM
Post Module Display Pec/Dir Gregor B. Avid S4/S6 1 03-10-2021 05:04 AM
Changing Display Module Views From the Surface itsmemagic Avid S4/S6 6 10-19-2019 03:49 AM
