Old 03-27-2023, 09:26 AM
DigitalVortex DigitalVortex is offline
Default Nudging the clip content without nudging the clip itself
Ok, another one.
I recall there was once a way to nudge the very wave content inside a clip (being in the "Waveform"-mode in the Edit window) without actually moving the clip block itself. You could then see the waveform move left or right visually.
Any who knows how to do that? It's a great time & energy saver!
Regards!
Old 03-27-2023, 09:30 AM
smurfyou smurfyou is offline
Default Re: Nudging the clip content without nudging the clip itself
I think they call it Nudge Clip Content.
On Mac it's CTRL and + or - on the numeric keypad.
~Will
Old 03-27-2023, 11:51 AM
Yes, that's it! Thanx man!
I did a research based on this and on Windows it's: Win (or Start) and +/-
However, not wonder at all why I stumble across it so mega seldom. Now, when testing it on a short clip it takes 2 seconds to move the content. Which is absolutely snailish in a workflow. Also if not zoomed in it's almost undetectable.
Not sure if it could have to do with CPU, GPU or something else. I have an AMD Ryzen 5 3600X 6-Core processor, so it's not that. And my graphic card isn't that bad either: NVIDIA GeForce GTX 960.
Regards!
Old 03-27-2023, 03:00 PM
Not sure why it would be slow, mine is instant.
But I'm running MacOS 10.15.7 and PT 2022.7 so not current.
~Will
Selecting a clip in Edit window fails to select clip in Clip List oldskool Pro Tools 2020 8 09-28-2021 01:43 AM
Nudging, trimming, sliding clip content, etc. don't work XJENSEN Pro Tools 2020 3 12-03-2020 10:14 AM
Nudging a clip past another clip removes the stationary clip evil.beasts Pro Tools TDM Systems (Mac) 0 11-01-2017 11:08 AM
Retain Loop points whilsnt nudging a clip phillyt2k Pro Tools 10 12 06-11-2014 01:22 PM
Nudging regions content in PT 5.0 Kenshiro Pro Tools TDM Systems (Mac) 2 11-26-1999 01:35 PM
