Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #21
Old 05-14-2023, 07:33 PM
Tone_Mechanic Tone_Mechanic is offline
Default Re: MTRX Studio distortion on outputs
Originally Posted by menno1000 View Post
Hi All,
Tone_Mechanic is right. MTRX is sensitive to balanced /unbalanced.
This is the cause of the distortion.
@Tone_Mechanic do you have fix for the unbalanced issue? A different way to connect balanced to unbalanced?
It may require some experimentation to find what works the best, and doesn’t cause an unnecessary drop in level.
You might want to try to contact Digital Audio of Denmark tech support (the makers of the MTRX and MTRX Studio) and find out. It’s a bit surprising to me that if this is a problem, they haven’t documented it already in the install manual.
But I would experiment with disconnecting either the ground, or the - signal.
Traditionally with a transformer output (which the MTRX is not) you would connect:
Balanced XLR
+ (pin 2) = + (Tip)
- (pin 3) = GND (Sleeve)
GND (pin 1) = GND (Sleeve)
For electronically balanced outputs, the configuration would be either:
+ (pin 2) = + (Tip)
GND (pin 1) = not connected
Or
+ (pin 2) = + (Tip)
- (pin 3) = not connected
The last setup was what was recommended for the 192 I/O.
One of the above setups should work, and will be clean and without distortion.
The other one will probably not work, be filled with hum or just not pass signal at all.
So you’ll just have to try both.
You could get balancing transformers, but that would add coloration and expense.
  #22
Old 05-15-2023, 04:32 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
The output of the MTRX/MTRX Studio should always be connected to an unbalanced input like this:
GND = GND
- = do not connect
Do note that this will result in unbalanced operation and the output level will therefore be 6 dB lower when compared to balanced operation.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Last edited by ntp-jl; 05-15-2023 at 11:48 PM. Reason: Typing error that could be misunderstood
  #23
Old 05-15-2023, 03:10 PM
menno1000 menno1000 is offline
I wrote an email and they said i had to turn to AVID or my reseller. Non of them responded. Avid i had to pay, ofc.
Thanks Tone_Meachanic. It turns out you got it right!
  #24
Old 05-15-2023, 03:14 PM
GND = GND
- = do not connect
Do not that this will result in unbalanced operation and the output level will therefore be 6 dB lower when compared to balanced operation.
Thanks for this Jan, very happy you joined.
Now i have confirmation about this. A 6dB loss is no problem. Without the described connection i had a 18dB loss.
Just to get the picture: is the signal still good if i did remain below the +6dB of output trim when if connected - to GND? Or is the signal already compromised below that output level in that order?
  #25
Old 05-15-2023, 11:03 PM
GND = GND
- = do not connect
Thank you for the confirmation!
  #26
Old 05-17-2023, 12:59 AM
ntp-jl's Avatar
Signal is only good if you connect as I have described.
Jan Lykke
  #27
Old 05-17-2023, 01:53 AM
Thanks!
MTRX Studio Headphone Outputs vs HD Native Thunderbolt Box scottmckay Pro Tools | MTRX & MTRX Studio 3 07-28-2022 09:22 PM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX Studio & AES Outputs talkbacksound Pro Tools | MTRX & MTRX Studio 25 01-28-2022 06:42 PM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX Studio and Rednet PCIeR card - no outputs above 32 ampnerd Pro Tools | MTRX & MTRX Studio 4 06-25-2021 09:02 AM
