Hi folks,
the title says it all. I have a wav file playback in 440 HZ but the musician wants to be recorded in 443 HZ. I have heard that you can somehow change the playback speed in Pro Tools, so the musician can hear the playback in 443 HZ and record in his comfortable tuning but the final WAV File result will be 440 HZ when played back at original speed. . Can anyone guide me through the settings about how to achieve this in Pro Tools for me to get a better understanding. Thanks a lot, lokotus |
Hi, welcome to the community.
Musician just tunes the instrument by 443Hz, not 440Hz. It has nothing to do with sampling rate. If you need to re-pitch pre-recorded audio you need to process the files (443-440)/440*100=0.68% higher
![]() Quote:
Not all hardware can do this! The MTRX units can't do varispeed (Dante will not do varispeed.) The HD IO can, the HD MADI can only when set to 56ch/48kHz, other third-party hardware can (like some of Antelope's which is used at Synchron Stage regularly in varispeed) The SyncX and SyncHD (and there are other master clocks) can be used to set the varispeed. (but once again, not all master word clocks can do varispeed.) You need both (audio interface and master word clock) to be able to do varispeed in order to do this. There are some CoreAudio/non-HDX hardware interfaces that can do varispeed but I don't know if Pro Tools will complain if they are at non-standard sample rates. The usual way (the only way I've done this) is with HDX hardware.
Pro Tools Ult 2023.9, HDX 3, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, FireHD x 2, Dock, iPad • Mac Mini 14,12, 12 core, macOS 13.6.1 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 09-29-2023 at 12:27 PM. |
RME in the past have said CoreAudio does not play well with Varispeed, ASIO can but I think there may be other issues doing this with their USB interfaces. I remember asking and looking at their forum and my head hurt too much to want to go further.
You can use Elastic Pitch to change any existing 440 audio by pushing it +3 cents.
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
The OP's post had me curious about 443HZ tuning and I found an informative article on iZotope's website.
A little excerpt: "For example, The New York Philharmonic uses 442 Hz, the Boston Symphony Orchestra uses 441 Hz, and many symphonies in parts of Europe use 443 Hz or 444 Hz." Full article here: https://www.izotope.com/en/learn/tun...explained.html
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
![]() Quote:
As BScout says, the right way to do this is with a system that allows VSO. If you can't do that and it's only one instrument that's at 443, I'd make a ref mix of the other tracks, pitch it up 12 cents with some utility like Pitch 'n Time/SoundShifter/Elastique, record the 443 instrument to that, then pitch it back down to marry with the rest of the tracks. If it's mostly 443 instruments, then I'd just pitch up the other instruments to match and go with that. Much less ideal than the VSO scenario, but workable.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.6.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Thanks for the correction
thank you very much for the detailled answers - a lot to learn here
![]() Quote:
Where to record audio files to | PhilipKapadia | Windows | 11 | 09-21-2022 03:07 PM |
Lost files and can't record. | PhilCurry | Pro Tools 12 | 2 | 05-18-2020 02:19 PM |
How To Convert Session From 440hz To 432hz | Aten | Windows | 8 | 05-15-2017 05:43 AM |
I/O error (-36) cant record wav files | mozet_tre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-06-2009 07:51 AM |
Can I record as .wav files on a Mac? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-11-2009 04:23 PM |
