Old 03-04-2000, 10:09 PM
delphypop delphypop is offline
Default running your system lean
in an effort to get my system to run faster especially with screen redraws I was trying to figure out what extensions and control panels were absolutely necessary to run protools.
I dumped a bunch out and then found that PT couldn't find my password files or something like that so had to put most of it back in again.
does anyone have a minimum strip down list of what they use to run protools at its fastest
I have an ATI video card to run dual monitors, and I was told I don't need the ATI extensions cos Macs run it automatically. Howbout things like ATI graphic accelerators and 3d accelerators. will these add speed to screen redraws etc.
cheers etc
Rob
Old 03-05-2000, 03:45 AM
DigiTechSupt's Avatar
Default Re: running your system lean
Mac OS Base set plus the Digi and OMS extensions is what is used for testing at Digi.
You can turn the printers off that are included in the base set but other than that I leave all the rest in the Base set on.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 03-05-2000, 05:41 PM
what about things like keyboard, appearance, mouse etc, are they absolutely necessary for PT?
how bout the ATI extensions, which ones are necessary and useful for faster graphic redraws etc?
Old 03-06-2000, 06:42 AM
AdamFrick AdamFrick is offline
I have the ATI 3d accellerator, driver update, 3d rage accellerator OFF -- otherwise my system won't run (too many 6042s). Don't know for sure if the basic accell is needed or not, but the others certainly are not.
-adam
Old 03-09-2000, 07:41 PM
does anyone know which extensions will get you better graphic speed performance, ie does quickdraw help withspeed, or does it just give you more accurate colours?
Purpose of lean extension set John Link Digidesign Hardware & Software 7 11-07-2023 09:47 AM
so i just got my new mac PT system up and running idleave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2009 04:51 PM
Running v8 and 7.4 on the same system? cKaz Pro Tools TDM Systems (Mac) 2 04-10-2009 11:12 AM
how to tell if your system is running right? xodiac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-12-2008 08:24 PM
What are you running on your system? Dreamware 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-28-2001 06:10 PM
