Old 10-29-2021, 06:25 PM
TommyT TommyT is offline
Default PT 2021.10 No Go on Mac 5,1 with Eucon & Artist control
So after updating - Protools crashes on Bootup... Seems 2010.10 is not compatible with artist mix.... I upgraded EUcon to 2021.10 but no go. crashes on initializing controllers... I deleted PT prefs & uninstalled Eucon & seems to be booting up.... ARG... Seems to work fine on my 2nd identical non EuCon Mac System....
Mac 5,1 / Catalina / 96gbRam/ HDX / Omni / Artist Mix / All SSD's
Old 10-29-2021, 06:38 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Re: PT 2021.10 No Go on Mac 5,1 with Eucon & Artist control
Works fine with mine using an Artist Control (not a mix).
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6.6 : Carbon : PT Ultimate 2024.3.1 : S1 : Metagrid Pro
Old 10-29-2021, 06:40 PM
Hmmm..
Old 10-29-2021, 08:14 PM
Just saw your sig. I’m on Mojave. HD Native.
Kerry Smith
Old 10-29-2021, 08:27 PM
BScout BScout is offline
Is your firmware up to date on the mix?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.7RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 10-29-2021, 08:51 PM
Yes Current firmware... I ended up purging all eucon software - via uninstaller But PT was still looking for some eucon library, so ended deleting PT prefs so it's not looking for the eucon, now seems to be working..... gonna wait & see what other users says with my setup.. before I try to re- install. lost half a day messing around -& need to get some work done....
Old 10-29-2021, 09:47 PM
Was the question from ProTools about Eucon personality missing?
Old 10-30-2021, 12:13 AM
off the wall's Avatar
off the wall off the wall is offline
What are you using to get to Catalina? A patched OS like Dosdude or Open Core. It's possible you've got something incompatible going on there.
I know it doesn't help you but I run a 5,1 with Big Sur and PT 2021.10 just fine but I have an Ethernet C|24 controller, no Econ at all.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.5
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 10-30-2021, 12:19 AM
Eric Lambert's Avatar
The older, silver, Euphonix-branded hardware, or the newer, silver, Avid-branded hardware?
Old 10-30-2021, 04:23 AM
The Dark last version Avid Artist Control. Yes after I uninstalled Eucon I got the missing personality error, so I deleted all PT preferences & solved that... OS instal involved the entire cheese grater graphics card swap out, firmware flash & usb drive image install.. Once I removed Eucon - seems to work fine so far..
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
Artist control/ Mix not working in PT 2021.3 gtole2 Artist Series 1 06-11-2021 09:24 AM
Eucon 3 - Artist Control not connecting to PT Trazan Artist Series 50 04-04-2016 03:14 AM
ATTN JC. Eucon 2.7 + Artist Mix/Control via HUI Herbieoz Artist Series 5 01-09-2015 02:14 AM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 01:21 AM
