Old 08-16-2012, 11:39 AM
cytokinesis cytokinesis is offline
Default Issue setting up HUI control
I've borrowed a friend's Tascam FW-1082 and was hoping to use it as a control surface. I've tried connecting the Firewire and it's not being recognized by it's control software so I tried just setting it up to send MIDI commands. The MIDI IN light on the 1082 is flashing red and when I move faders the MIDI OUT light flashes green for a second then Pro Tools tells me it can't properly communicate with the HUI device.
Chain is as such:
FW-1082 MIDI I/O CH 1 -> M-Audio ProFire 2626 MIDI I/O -> PT9 on Mac OS 10.6.8 2.7 Ghz i5 w/ 8GB RAM
Any thoughts? I feel like I'll be kicking myself as soon as this is resolved...
Old 08-16-2012, 02:15 PM
jwd jwd is offline
Default Re: Issue setting up HUI control
Someone more informed than myself might be able to correct me, but...
I'm not aware that PT supports firewire controllers (though there is the 003). Ethernet might be the way to go regardless, assuming that's an option with that unit. Plus I've always known HUI (and gear that emulates HUI) to be mostly (if not solely) ethernet (or midi?) controllers.
EDIT: I did some quick googling and I couldn't find any protools firewire control surfaces...only firewire audio interfaces. Though the MIDI should work, provided it's a HUI supported device. I'm not really aware of a lot of the newer rules regarding control surfaces, so I'm mostly speaking in terms of the way PT has handled this previous to V9/10.
Also, I'm assuming you're setting everything up in Setup/Peripherals/MIDI(or ethernet) controllers - and all of your ins and outs are correct.
Old 08-17-2012, 03:40 PM
Yep, double checked my ins and outs and have it set up in the peripherals dialogue. From what I've read, it says it is HUI compatible, I just can't seem to make it work properly.
Old 08-21-2012, 07:16 AM
jwd jwd is offline
it makes more sense once i googled the controller. it's essentially a tascam version of a 003. tascam says it's compatible w/ protools as a HUI surface.
in peripherals, you also have HUI selected as type?
you might want to check your mac's Audio Midi Setup to see if this thing even shows up there.
and also in protools...
setup > MIDI > Input devices (make sure the controller is selected)
I've never owned a 002 or similar, so I'm guessing based on my experience with other stuff. :)
Setting up a Control 24 ics ProControl, Control|24, Command|8 7 01-15-2024 12:31 PM
Issue with Setting Time Stamp jb_trm Pro Tools 11 4 08-19-2013 03:31 PM
Issue with setting "Timing" jambirn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2006 08:57 AM
Setting up ADR Studio with a Control 24 paronoff ICON & C|24 2 07-28-2005 02:25 PM
Help Setting up Machine Control 2 in OS X autopilot Pro Tools TDM Systems (Mac) 3 06-02-2005 08:15 PM
