Old 03-11-2010, 02:13 PM
HDK_Ent HDK_Ent is offline
Default Unstable
ok, well aside from the fact that my computer is up and running and recording again, it seems to me that its being a bit unstable. sessions where all the audio files are there, when pulled up, are telling me that some are missing.
also when i tried bouncing a session today, pro tools first returned an error, stating that there was an error with the bounce and that it had to stop, when i tried it again, it just froze up on me and i had to cancel. also now whenever i load a session it lags up on it, and by lag i mean, for about 30 seconds or more.
i know that this is unusual behavior, considering the session im pulling up has 1 stereo track, and 4 mono audio tracks. no plug ins, busses or inserts on the whole track. so im left in shock and awe.
a 1200 i7 pc should not run like that. shoot, even my old gateway i used to use didnt lag up this much...
ill port another sandra inna minute. there has to be something wrong here...
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
6 GB Corsair XMS3 Ram,
WD 500GB 7200 rpm HD,
WD 750GB 7200 rpm HD,
MBox 2 Mini, PT LE 8,
Axiom 49 Midi Controller,
Akai MPK 61 Midi Controller,
AKG C-414 Microphone.
Wish List: 2 Months.
Digi 003 BLA Mod,
MBP i5, 2.53 Ghz, 4GB of ram, 320GB internal, 500GB External Firewire, Waves Mercury,
Dverb Test - 156
"How you gon' do an 'Intro' to an 'Outro'?"
-Steezy on "Goodbye" By Spliit
Old 03-11-2010, 02:19 PM
caruso7r caruso7r is offline
Default Re: Unstable
Check if all your plugins are compatible. Even if they're not loaded into a session, you could run into problems with incompatible plugins. Based on other threads you posted, you might have some incompatible "waves" plugins unless you already upgraded.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 03-11-2010, 02:20 PM
TOM@METRO's Avatar
Rest assured there is something wrong and you will ultimately find it. Looking forward to the Sandra.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-11-2010, 02:32 PM
could the waves plug ins really be causing me those kinds of problems? im waiting for sandra to finish downloading. then ill restart and post it...
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
Digi 003 BLA Mod,
Dverb Test - 156
Old 03-11-2010, 02:34 PM
Definitely it could be the "waves" plugins. But we'll wait for your sandra report. EDIT: You mentioned your old Gateway didn't have these issues. Did you have the same plugins installed?
John
Pro Tools 12.5
Old 03-11-2010, 02:36 PM
TOM@METRO's Avatar
I have suspected this from the start.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 03-11-2010, 02:49 PM
everything was identical in my old gateway... honestly i have no clue how i even recorded or mixed on that thing, it was by chance that pro tools even loaded up, i never had any idea about all this compatability hardware stuff till recently when i joined...
i had a 1gb video card, 4 gigs of mis matched ram, ranging from generic ram to kingston.
i had 2 hard drives, one 80 and one 160, and they were horrible generic hard drives from ebay.
i had windows xp home cs1
and a mbox 2.
now that ive learned a ton more information as far as compatibility it stumps me how i ran pt le 8 with all these plug ins working perfectly, given the OCCASIONAL but rare 90xx errors...
it stumps me...
but the sandra, yes, give me one min to restart my comp its done installing.
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
Digi 003 BLA Mod,
Dverb Test - 156
Old 03-11-2010, 02:55 PM
What drive are you recording to? Your quickie description only lists a single drive. The quick way to check on the Waves is to pull the files out of the Plugins folder(just drag them onto the desktop). C:>Program Files>Common Files>Digidesign>DAE>Plugins and drag out anything that has Waves in front of it. Open PT and try any session. OR, hold the shift key while you open a session as that will disable all plugins(right-click on the plugins to re-enable them by choosing "Make Active")
Old 03-11-2010, 02:56 PM
sw rec sw rec is offline
Didn't see a dedicated audio drive in there anywhere.....
Old 03-11-2010, 03:31 PM
i have to fix my sig, but i do have 3 drives. 1 for reason 1 for pt and 1 for os...
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
Digi 003 BLA Mod,
Dverb Test - 156
Why is PT so unstable for me? typhy macOS 1 07-31-2012 12:55 PM
PT 9.0.5 - so unstable anackman macOS 4 10-24-2011 01:09 PM
Why is PT 9 so unstable? tblythe.sound macOS 44 05-07-2011 02:19 PM
AAF unstable? jackisdead Post - Surround - Video 2 08-26-2008 03:01 PM
Mac? Unstable? link 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-05-2000 03:57 AM
