Old 11-30-2005, 03:54 PM
rockwithrespect rockwithrespect is offline
Default Terrible RTAS Latency in 6.9
I downloaded the new Waves 5 Diamond Bundle and installed it. I was messing around last night, just jamming a little bit, and started throwing plugs on the master track while I was recording. The latency was HUGE! Probably a whole second.
I thought maybe I had my Playback Settings jacked up from a previous mix session, but my CPU usage was set at 99% and Buffer was at 256. The system usage showed nominal CPU use.
For the record, I had one stereo Aux track routing Reason into PT. One midi track with some simple drum programming. One audio track with an Amplitube LE plug inserted. One stereo master fader with Waves LinMB inserted.
Before I got PT LE 6.9, I was running 6.4 with numerous plugs while tracking, and within reason I never had any problems. Is this a problem with Waves 5, or with PT LE 6.9?
Thanks. I'm worried I may have to revert to 6.4 if I can't get this figured out. I like to use some plugs while doing overdubs because I think people play better when they sound better. I haven't done a session with 6.9 yet, but if this is the performance level that can be expected, I'm going back to 6.4.
System:
1.25 DP G4
2 Gb RAM
OS 10.3.9
PT LE 6.9
Kyle
I've seen a million faces, and I've rocked them all.
Old 11-30-2005, 05:32 PM
Matt82au Matt82au is offline
Default Re: Terrible RTAS Latency in 6.9
waves linMB is the culperit here. from memory it introduces about 3800 samples of delay alone. close to 1/10th of a second. hold down apple and click on the green "vol." on the bottom of each fader in your mix window. click there twice and you will get the number of samples of delay been induced by your pluggins. you can then manually nudge the track back that many samples to get sync once again.
hope this helps!
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
Old 11-30-2005, 07:18 PM
I'm sure LinMB is mostly to blame, but basically anything on the Master, from T-Racks, to BF76, to Vintage Warmer induced noticable latency. I used to track with plugs on the master all day long in 6.4 with no problems whatsoever.
Does anybody have any ideas or settings I should track down and edit? Thanks!
Kyle
Old 11-30-2005, 07:34 PM
Waves Linear MultiBand compressor introduces delay because it HAS to - it's not intended for use during tracking. It's more of a mastering tool.
It's the neature of linear phasee algorithms that they need to save up some results before sending anything out. Unavoidable.
Quad 2.5 G5, 4.5G RAM
Terrible latency on brand new i7 PC Mike Cleary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 32 02-19-2010 10:37 AM
Terrible MIDI latency problems grantmaloysmith MIDI 0 07-27-2008 02:17 PM
MDW RTAS latency??? EvilElfBoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-20-2007 04:44 PM
latency with rtas plug halfguard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2005 09:52 PM
Latency compensation in RTAS.. JBRecording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2003 03:35 AM
