Hardware insert latency??? What...?
Ya so, I'm mixing this song using a hardware comp on my vox bus and after bouncing, I'm listening and maybe I heard this song to many times but I have the impression the vocals are late. Buffer is at 1024, maxed out on plugs...
Is this it? Insert latency? The signal leaves the interface, goes to the comp then comes back delayed? The thing is I dont hear in this in playback, only after bouncing... Weird. Care to comment? Thanks in advance LoZion
"The secret in life is to have no fear" Fela Anikulapo Kuti |
Re: Hardware insert latency??? What...?
Yes, the buffer size is doing it. Maybe you can print the vox down, and nudge them back.
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
Hey, thanks for the reply.
The funny thing like I mentionned is that you only notice it after bounce and not during playback. I wonder if its a bounce handler problem. Well, I decided to insert my tube comp on the mix and use a fairchild plug (I was doing the opposite) on the vox bus and that of course took care of the latency since the whole mix is delayed equally. You're right I could've printed the vox and move them up but enuff with this song for tonite, my hears are full... Plus, the added upper harmonics of the tube comp are nice on the whole mix and not just the vocals... later,
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Hardware Insert Latency issue in Pro Tools 10!!! HELP !!! | Hovak | macOS | 14 | 10-28-2012 10:42 AM |
How to insert hardware as channel insert | Lqoau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-19-2012 07:29 AM |
I/O insert latency in HD Native | jacko | Pro Tools HDX & HD Native Systems (Mac) | 10 | 05-06-2011 04:45 AM |
Insert and Latency | Hedgehog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-09-2005 02:55 PM |
