Old 12-15-2004, 09:52 PM
aandina aandina is offline
Default using iTunes with Mbox and Core Audio
can anyone help me to use iTunes with the Mbox? I'd like to use the Mbox outputs fot iTunes but I still haven't found how to set the preferece.
Best Regards,
Angelo Andina
Italy
Old 12-15-2004, 10:14 PM
Musick Musick is offline
Default Re: using iTunes with Mbox and Core Audio
You need to use DigiDesign's CoreAudio.
And on you Mac, under System Preferences, in Sound Preference select your MBox as the Output.
Launch iTunes and you'll be set...
Old 12-19-2004, 02:58 AM
and thanks for your help. Unfortunately when I switch to the mBox output iTunes stops playing, in other words, even if the play button is pressed it remains still... when I switch back to the internal output iTunes begins to play again, what's happened?
Best Regards,
Angelo Andina
Italy
Old 12-19-2004, 03:57 AM
mersisblue mersisblue is offline
you changed your sound card . ( did you / do you ) have speakers set up on your m box ? Itunes should play to the M box outs .
But not when pro tools is on .
Old 12-19-2004, 07:20 AM
and thanks for your reply. No, I haven't changed my audio card and no external speakers connected. I've tried to use iTunes with the mBox only with Pro Tools off. Are there other reasons for my system not to work?
Best Regards,
Angelo Andina
Italy
Old 12-19-2004, 09:30 AM
yOkO yOkO is offline
while it´s supposed to work, i´ve had problems with core audio manager,
even with the last one, not say with itunes, it won´t crash,
but it may sound or not, with garage it would sound nice when i choose it in
preferences, then i go out, relaunch, and it sounds like bsshhtssshss,
with live, no problems, with reason, (not rewired but standalone i'm talking)
sometimes it works sometimes not. i'm talking core 6.5.2
so with apple aplications i have stayed with internal card,
and with others i use core only if it work smooth.
so what
Core Audio-Itunes Greene Pro Tools TDM Systems (Mac) 2 03-12-2006 04:04 PM
Using Mbox Core Audio for iTunes, FCE, GB, etc. benom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-11-2004 11:28 AM
Core Audio and iTunes chrispnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-18-2004 03:54 PM
002 Core Audio w/ Itunes Rustyd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-03-2003 04:43 AM
iTunes 4 and 001 core audio gonzolagonda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2003 06:23 AM
