Recording to Dat through lightpipe?
I am not able to get my Sony Dat to recognize the optical output from the Digi card. Has anyone come across this problem? The s/pdif works fine, but when I switch it to optical mode the Dat refuses to go into record.
------------------ flytrap The Acid House Somerville, NJ
flytrap The Acid House Somerville, NJ |
Re: Recording to Dat through lightpipe?
To perform Optical transfers from Pro Tools into any 2-channel optical digital device:
-Setups>Playback Engine>Other Options: Optical Mode=S/PDIF -Setups>Hardware: Digital Sync mode=Internal -Sync mode on remote device must be set to External or Digital -Rec-enable the DAT -Play the session (you should see activity on the meters of the DAT). Brent |
Thanks Brent! Totally works, Dude.
Problem with lightpipe recording | jaxx | macOS | 7 | 03-29-2013 04:55 PM |
Lightpipe cap? | Kolchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-03-2011 03:30 AM |
LIGHTPIPE I/O | detroitkruk | Pro Tools M-Powered (Win) | 3 | 11-03-2007 06:30 PM |
001 with LIGHTPIPE | atrest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-05-2003 08:17 PM |
Lightpipe VS AES/EBU | ryan de topanga | Pro Tools TDM Systems (Mac) | 3 | 12-03-2002 10:41 AM |
