Re: Clocking the Digi 001?
Thanks Thomcat.
MisterMe, When you say that the Tango is the master and 001 is the slave are you just setting the 001 to sync to the optical input in the hardware control panel? or are there other settings that you configure? ------------------ flytrap The Acid House Somerville, NJ
flytrap The Acid House Somerville, NJ |
ThomCat - That's all true. Besides, from reading your post in the other thread, you know waaaaaaaaaaaaay more about the Rosetta than I do. I just like Purple
Flytrap - The Digimax goes into the Optical, but it's receives word clock from the Rosetta (master clock), therefore, the Rosetta's clock goes through the Digimax and into the 001. If you set the 001 Sync Mode to Optical, It will receive clock from whatever unit you've selected as your master, no matter how many units it passes through (or you can afford) on the way there. ------------------ bassmac |
I recently "over-clocked" my 001 and now my sessions go twice as fast!
Dan-
http://homepage.mac.com/dkrausz |
PT 11 / Digi 002 / SPDIF not clocking?? | jeffpardo | Pro Tools 11 | 1 | 01-12-2014 10:38 PM |
Digi 003, focusrite 428 and clocking | kvnlnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-03-2010 09:31 AM |
More errors when clocking from external AD/DA...DIGI PLS HLP | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-28-2008 10:47 AM |
Digi 001 & Yamaha O1V clocking issues | jj3567 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-23-2006 05:25 PM |
Digi 002r clocking problems | arkestra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2005 10:38 PM |
