Old 01-15-2020, 10:33 PM
March314 March314 is offline
Default Dynamics drop down doesn't show full plug in list
Hi. Everyone.
I'm having an issue with my Dynamics tab in the plug ins menu. Its showing all plug ins from "Zero - P" then skips "Q, R, S, T" then shows "U - V". I've searched the web and it seems like i'm the only one having this issue. If there's anyone out there that may have had or is having this issue, and knows a fix, id greatly appreciate the info.
Old 01-16-2020, 01:37 AM
BScout BScout is offline
Default Re: Dynamics drop down doesn't show full plug in list
The problem is your screen resolution. The list is just cut off by the bottom of your screen.
Are you running the native resolution for your monitor or scaling up your resolution?
Pro Tools Ult 2021.12, HDX 3, MTRX/SPQ, HD Omni • S1 x 2, FireHD x 2, Dock, iPad • Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6 • RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 01-16-2020, 04:43 AM
Southsidemusic's Avatar
Yep we thought this was a bug a long time ago too but the list is there at the bottom so as BScout said you need to change the resolution. Also isn’t there a small arrow at the bottom for scrolling down the list?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-16-2020, 04:25 PM
Since his/her list is going to 2 columns, probably not.
(and if there was, it'd be cut off the screen too)
Old 01-16-2020, 04:28 PM
Aha Got it!
So resolution of the screen is key here.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-03-2021, 12:09 AM
Songster Songster is offline
I've got the same issue with plugin lists. I have 2 monitors with the display extended. They are different monitors and sizes. When I pull up the list on the top screen in edit or mix windows, the list stretches to the bottom of the lower display, then starts on the the top of the top display. But when I click the list on the edit or mix window on the bottom display, the same list goes off the bottom of the display and starts on the top of the lower display leaving out the whole section of plugins.
This happens with busses too, but on the AVID plugins, the small scroll arrows are at the top and bottom and I can page thru them... not with others, such as WAVES. I've changed resolutions but that didn't seem to help. I'm using PT 2021 with Windows 10, but this problem has been around for many years and versions. Would be nice if it got fixed for as much money as we spend on this program and support.
Old 12-03-2021, 08:17 AM
This is why the Search option gets a lot of use here
Old 12-04-2021, 03:24 AM
Skwaidu Skwaidu is offline
It happens to me too. I thought it was a thing with my "unsupported" Win11 but apparently not.
FWIW my main screen where I see this is running natively at 1440p, then I have 2 1080p screens that start extending the desktop from the right side of the main screen.
Windows 11, Intel i9-12900K, MSI PRO Z690-A D4, 64 GB DDR4 3200MHz/CL16, Corsair HX1000, 1x PCIe 4.0 1TB, 1x PCIe 3.0 2TB, 2x WD Black 6TB, Noctua NH-D15, Fractal Design Define R6 + GTX960 (for now) - PT Ultimate 2021.10
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, OSX Mojave, PT Ultimate 2021.6
HDX2, HD I/O 16x16 and ICON D-Command ES.
EZ Drummer doesn't show up in Inst.list rchambrz Pro Tools 12 2 11-21-2015 10:24 PM
Maschine 2 AAX does not show up in Plug-In Drop Down PT11 Demo johnnybregar Virtual Instruments 1 02-28-2014 01:41 PM
Plug-In Will Only Show On Drop Down Menu DJLilSteve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-04-2010 09:44 AM
Please help- PTMP 8 doesn't show LIVE in plug in list Tool99 Pro Tools M-Powered (Win) 0 08-22-2009 10:37 PM
why doesn't analog factory show up on my instrument list? Phatbeats Virtual Instruments 6 08-25-2007 07:38 PM
