Old 06-23-2009, 04:10 PM
Numi Numi is offline
Default Sustain Pedal Not Working
I am using Pro Tools 8cs3, and a M-Audio 61es...and I don't know if I am doing something wrong, but I cannot seem to get PT's to read any of my sustain pedal information. I am connected via USB for the MIDI controller. All other data is recorded just fine.
I have an instrument track setup, with the Mini Grand. I can play any key, use my mod wheel and volume knob no problems. I am wondering if my pedal is damaged? or maybe something else I didn't think of is not enabled? I haven't adjusted anything in midi properties, and haven't used my keyboard in quite sometime(but it worked a while back when I was using PT's 7.4.2). So all settings are default for everything. I get great sounds and low latency from the Mbox 2 Pro, just no info coming from the sustain pedal at all. Strange.
Any Ideas? Thanks in Advanced for any help!
Old 06-23-2009, 05:55 PM
Default Re: Sustain Pedal Not Working
Well, I rebooted...and it started working again.
Old 06-24-2009, 02:34 PM
chrono4548 chrono4548 is offline
I was having the same issue. I just restarted and everything works well now.
Sustain pedal not working with pro tools 10 Fyenamuzik macOS 4 03-30-2013 04:26 PM
Sustain pedal not working with Mini Grand Gothboy Virtual Instruments 0 06-22-2009 11:31 AM
midi sustain pedal not working in pro tools le 7.4.11 protoolsle123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-24-2009 05:50 PM
midi sustain pedal not working in pro tools protoolsle123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-14-2009 02:31 AM
Sustain pedal not working - Reason to PT LE totemspock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-12-2004 03:28 AM
