Memory Location Marker Does NOT Update After Edit Cuts
Problem:
After I Edit Cut/Trim a time selection in a session (i.e., Cutting/removing a verse early in a session, etc,), the Memory Location Markers do NOT update their actual new time locations – the time does not shift downward to follow the new shorter length of the session – I have to go back and move all Markers manually. Example: Song Structure: Verse 1 (Vocal), Verse 2 (Vocal), Verse 3 (Lead Guitar), Turnaround (End) Session (Song) length: 4:30 min Lead Guitar Marker set at: 3:00 min Cut/Removed the 2nd Verse between 2:00 – 3:00 min Session (Song) length AFTER Cut: 3:30 min Lead Guitar Marker STILL shows: 3:00 min, DID NOT UPDATE to new actual location at 2:00 min It appears that the Markers are ONLY hard pinned to the actual time location when the Marker was created but I need them to “UPDATE” after I add/remove time to the middle of a session. All Markers AFTER the Edit Cut section should auto-update – shift down in time to match the shorter session (song). How do I get this to work? Thank you for your assistance.
ProTools 2021.12, Lynx Aurora (n) 32 TB, Sibelius 23.2.0; OSX 10.14.6; Mac Mini: 3.2 GHz Intel Core i7; 64 GB 2667 MHz DDR4; Internal 2 TB SSD, External Sabrent TB 2 TB SSD Also ProTools 2021.12, 002R,; Mac Pro: 2 x 3.46 GHz 6-Core Intel Xeon; 128 GB 1333 MHz DDR3 ECC; Serial ATA Drives (Journaled HFS+): 2 x OWC Mercury Electra 3G 2 TB SSD; 3 x Seagate Barracudas 1.0 TB; External Firewire Drives (Journaled HFS+): 4 x Seagate Barracudas 1.5 TB and 6 x Seagate Barracudas 1.0 TB |
Re: Memory Location Marker Does NOT Update After Edit Cuts
Include the Marker Ruler when making a selection.
filosofem
Aaron Mulqueen - 001 HD Native |
Sometimes you feel like a nut . . . . PROBLEM SOLVED! THANK YOU VERY MUCH!!!
Main Timeline Marker SHORT CUTS | jqchicago | macOS | 1 | 07-26-2013 07:38 AM |
Problems with Memory Location/Marker Import | thaumaturgist | macOS | 4 | 06-24-2013 06:09 PM |
Memory location edit without clicking? | Bob L | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-23-2011 10:24 AM |
Question about location marker | miketmbt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-24-2011 05:47 PM |
7.3 update jog scrub wheel and memory location | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-04-2007 02:43 PM |
