Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-11-2007, 08:20 PM
funkbaby funkbaby is offline
Default ProTools M-Powered quits when I try running at 96kHz. Help!
ProTools M-Powered 6.8 unexpectedly quits whenever I try to create or open a ProTools session @ 96kHz. According to everything I read about the program, it should work so long as the audio interface can handle 96kHz. Here is what I am running:
!.47GHz G4 Mac Mini
1G DDR SDRAM
MacOS version 10.3.7
M-Audio Fire wire 1814
Somebody please help!!!!
Generally, I have found ProTools M-Powered to be very "tweaky" compared to other versions of ProTools I've owned. Many of the tweaks I've encountered so far have involved simple setup changes to fix that should be included somewhere in the manuals. Does anyone else find this to be the case?
Protools M-Powered quits session when trying to create a new session on my MacBookPro Edavis229 Pro Tools M-Powered (Mac) 1 04-05-2011 02:33 PM
m-powered protools max 14 channels of 96khz ciank Pro Tools M-Powered (Win) 1 07-07-2010 08:50 AM
96khz Issue (also affects M-Powered) creator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-01-2007 11:49 AM
projectmix + m-powered at 96kHz? delpinator Pro Tools M-Powered (Win) 6 10-26-2006 01:19 PM
Protools LE & M-Powered 7 running simultaenously BCooLin Pro Tools M-Powered (Mac) 2 01-13-2006 12:48 PM
