Old 08-06-2021, 04:05 AM
[email protected] accardi@accardi.com is offline
Default Trim tool not working?
ProTools 2021 6.0 ....
Novice here ...
I created a midi track and now I need to trim the first seconds of silence from the beginning. I am using the trim tool in both the edit window and in the MIDI editor with the same disappointing results ... the cursor does change to a bracket correctly, but I cannot sweep out the section to delete. Why? Is the track locked somehow? Are there situations when the trim tool can't be used? Does it need to be fully enabled in some way? Thanks in advance for insights.
Old 08-06-2021, 07:20 AM
daeron80 daeron80 is offline
Default Re: Trim tool not working?
Could be you're in Grid mode with a large grid value. Try slip mode or a smaller grid value. F1-F4 select edit modes.
It is possible to lock clips. If the clip has a little lock symbol in the corner, select the clip on the timeline and press Command+L (Mac) or Ctrl+L (Win).
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 08-06-2021, 08:19 AM
Hmmm, why trim silence? Why trim silence on a MIDI track(which has no sound)? Have you set the track view to CLIPS? Knowing the purpose might get better advice
Some basics:
To use the TRIM tool on a midi or instrument track, the view needs to be set to clips. To use TRIM on an audio track, the view needs to be set for Waveform.
Old 08-11-2021, 02:34 AM
So that the clip starts on the nearest beat or bar, depending on how you might want to edit/copy/paste later. Neatness counts when working with MIDI on the grid.
David J. Finnamore
Coalescing trim automation on read-trim not working Oggy Pro Tools 2019 5 11-07-2019 08:49 AM
Trim Tool bug ballandbiscuit Pro Tools 2018 5 05-20-2018 02:42 PM
Trim Tool Omar08 Pro Tools 10 4 09-08-2014 04:32 AM
Problems with Grabber Tool & Trim Tool S133 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2008 10:19 PM
Need help with use of Trim Tool Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2008 10:07 AM
