Just hooked up to internet, go to laucne PT and error message pops up:\"INIT is req\"?
1. Protools was running smoothly.
2. I subscribed to Earthlink IP. 3. I had to make a change in Base 9: In control panel I enabled ARA server 3.5 and the 7 misc items that followed in that group, under the direction of Earthlink Tech support. 4. Then I went to TCP/IP control panel and changed setting to PPP, and "Using PPP server." 5. Now I can get on the internet with my G4, but can't get into Protools. When I try launching PT, the message "INIT is required" pops up, and dosn't allow me to start PT. 6. I don't understand, Please all informed, HHHEEELLLPPPPP!!!!!!!!! |
Re: Just hooked up to internet, go to laucne PT and error message pops up:\"INIT is req\"?
That happened to me when I upgraded to OS 9.1. I ended up popping in the PT disk and reinstalling it.
[This message has been edited by maxcap (edited March 16, 2001).]
Everyone in this room is wearing a suit, and don't kid yourselves Zappa |
good morning
I am guessing Earthlink TS asked you to duplicate OS 9.x base correct? That 'turned' off your digi inits + OMS. I would make sure they are 'on' ditto with all open transport stuff. Appletalk off. I keep Microsoft Internet set 'off'. Stay clear of IE 5.5 for the moment, as it's OS-x native IMHO. ..and use Netscape.
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
I ran into the same problem. Got my new mac, powered up, ran fine. Then installed protools which ran fine. Realized many capabilities (Primarily Internet related) had been disabled through the PT install. Came to the DUC and figured out it all had to do with extensions.
Do a search on extensions and you should find some useful suggestions, including setting up a couple extension setups for your various uses. You need to restart each time you change set-ups, but that's not too bad. |
CLOCK ERROR/NO HARDWARE HOOKED UP | SIM1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-01-2006 08:49 AM |
digisystem init error | mr_middas | Pro Tools TDM Systems (Mac) | 6 | 06-29-2005 08:22 AM |
HELP PLEASE!!!!!!! DigiSystem INIT bus error!!!!!! | atrest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-07-2003 04:12 PM |
INIT error?? | Alex Morales | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-13-2002 05:05 PM |
digisystem init bus error HELP! | pmklein | Pro Tools TDM Systems (Mac) | 5 | 01-17-2002 05:42 AM |
