Old 12-20-2013, 03:39 AM
digi003 digi003 is offline
Default Pt10 midi instruments sync issue with audio
Hi I'm hoping someone can help me.
I'm using the latest version of PT10, it was working fine until one of the updates before 10.3.7 etc
Now all my internal midi instruments are out of sync with audio on playback or even whilst writing .
I'm having to almost put a - delay on each instrument of around 20 ms to enable playback to be synced between audio / internal midi instruments.
it had worked previously before one of the updates but now even trying to revert back to a previous version of PT10 doesn't cure the issue.
Any help would be appreciated, my hardware is listed below....
please note no hardware changes have been made prior to it working correctly and now
PT10 , motu 2408 MK2, Asus M5A78L motherboard, 16Gb DDR3 , AMD Phenom II x 4 196T 3GHz CPU.
Windows 7 64
Protools 10: Asus M2N 1392 : 8GB Crucail DDR2 800 :
MBOX PRO2
Old 12-20-2013, 05:28 AM
Default Re: Pt10 midi instruments sync issue with audio
I hope someone can help with this as its almost pushing me to look at using a different DAW
MBOX PRO2
Old 12-20-2013, 05:45 AM
Question Re: Pt10 midi instruments sync issue with audio
Do you have delay compensation enabled? Setup-->Playback Engine
Old 12-20-2013, 10:33 AM
no I haven't tried that
MBOX PRO2
Old 12-20-2013, 10:38 AM
current settings,
H/w buffer size 1024
Host Processors 3
CPU usages 85 %
Host engine (ticked) (ignore errors during playback / record)
minimise I/o latency (un ticked)
Delay compensation (none)
plug in streaming buffer (level 2)
MBOX PRO2
Old 12-20-2013, 05:44 PM
What happens if you turn on delay compensation? Does the problem get better? Worse? No change?
Old 12-21-2013, 07:40 AM
no charge when turning delay compensation on
MBOX PRO2
Old 12-21-2013, 07:45 AM
Any change if you lower your hardware buffer to the minimum number of samples?
Old 12-21-2013, 09:11 AM
i'll re check that but i'm sure it didn't makr any differnce last time
i tried.
Thing is i was all working fine @ one point
MBOX PRO2
Old 12-22-2013, 03:34 AM
no difference
MBOX PRO2
PT10 Video sync issue Crossleyj Pro Tools 10 4 09-16-2013 08:42 AM
Help audio / instruments sync issues digi003 Windows 4 02-16-2013 06:32 AM
PT10 Midi Not in Sync Rups Pro Tools 10 0 12-27-2011 09:10 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Midi Timing Delay Sync Issue: MTC Sync daysean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 01-22-2007 11:48 AM
