can you assign plugins from the c24?
Re: can you assign plugins from the c24?
Yes. Here's the procedure:
1. Press the "Insert" button on the c/24 corresponding to the track you want to assign the plug on. 2. Press the button under the insert slot that you want to assign the plug. 3. Press the "Assign" button on the c/24. 4. Rotate the knob until the plug that you want is selected. 5. Press the "Assign" button again. |
HDX can't assign voices? | tribase | macOS | 1 | 03-22-2012 09:19 PM |
Is it possible to assign midi cc to controls in AIR plugins? | OutOnThePorch | Virtual Instruments | 1 | 09-24-2009 01:17 AM |
Can't assign output, not enough DSP? | crizdee | Pro Tools TDM Systems (Mac) | 2 | 04-04-2008 12:05 PM |
installing new TDM - how much RAM to assign to PT? | Namaste | Pro Tools TDM Systems (Mac) | 2 | 12-23-2003 06:08 AM |
assign ram | littlebear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-09-2001 09:54 AM |
