ENOUGH pops N clicks in sessions already!
i'm getting clicks n pops in both 6.7 and 6.9 on many of my sessions
i suspect amp farm but . . i'm not sure the pops happane big time on session opening up and when i re position faders in new placement. has this been milled over in here before. at first i thought it was my 88.2 sessions from a template i use but now i 'm hearing it on the 44.1 from time to time....then other times it seems to fix itself...what's up with this? this pops are a tannoy speaker lawsuit waiting to happen.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Re: ENOUGH pops N clicks in sessions already!
I would like to try to help you with this, but I need to know what troubleshooting you've tried and as much information about what is happening with your system as well as it's configuration.
Without a clear and concise way to reproduce the problem, we're just going to be shooting in the dark. |
it will go away once you deleat your DAE preference, Digi setup and Pro-Tools 6.9 preferences. Dont'really know why but we here in La suspect it's curpt DAE. That will fix it thought.
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
thanks KURT
i'll try this much props
Hey Jimi,
I once had a case of the 'random pops', turned out to be a bad ram module. HTH. |
did not have any today.
tonite is the south african rock band i'm producing. every one of their sessions pops at 88.2 perhaps the 9.2 PT is not doing it now today is my first on the clock session on the new tiger PT system 5 hours of vocals all successful thanks digi i keep hitting apple spacebar to record and launching than damn spotlight thing and there are a few other quirks but it ain't bad
To disable Spotlight, launch your Terminal (located in /Applications/Utilities/) and type the following:
sudo pico /etc/hostconfig This will open up your hostconfig file, which tells OS X what processes to launch at startup. Scroll down the hostconfig file and find the line that reads SPOTLIGHT=-YES- and change it to SPOTLIGHT=-NO-. Close and save the file. If you don't know how to use pico, type man pico to read over it's man pages first. If you want to remove Spotlight from the menu bar, remove the file "Search.bundle" from the folder /System/Library/CoreServices, but keep it around somewhere in case you change your mind. When you reboot the computer Spotlight will not load. If you ever want to re-enable Spotlight just go back through these steps and change NO back to YES and put "Search.bundle" back where it belongs. |
Pro Tools 8 Upgrade - Pops and clicks when opening 96k sessions | windstead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2009 11:52 AM |
mystery clicks/pops upon revisiting sessions | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-29-2007 07:09 AM |
Pops and clicks on heavy sessions | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-22-2007 11:28 AM |
clicks and pops | mkalei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-25-2005 10:26 AM |
horrendous clicks & pops being introduced by playback of strongly edited sessions | Hans Mues | Pro Tools TDM Systems (Mac) | 20 | 01-31-2001 03:13 AM |
