PT not recognizing Hard Drive as audio drive
Hey all,
I'm trying to record to my "E" drive which is a western digital IDE drive in a bytec firewire case. For some reason when I try to create a new session it says "Session must be on an Audio Volume". I've no clue ow to make the hard drive a valid audio volume. My setup is an 002r through a dell Inspiron 8500, 2.2 ghz, 512 ram, 30 gig system. The 002r is connected directly to the firewire port and the harddrive is daisy chained through the 002 rack. Windows XP service pack 1, PTLE 6.4 Any Ideas??? Thanks -Kevin
KP A+, MCP |
Re: PT not recognizing Hard Drive as audio drive
You can't daisy chain a harddrive through the 002, at least that's my understanding. Put the harddrive in it's own Firewire port, assuming you have a multiple.
From Answer Base, and I quote... "The second FireWire port on the Digi 002 is not intended for external hard drives or other storage devices, as this may result in unexpected behavior. It is recommended that Digi 002 be connected as the last device in the FireWire chain, or be connected to a dedicated FireWire port".
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Workspace Window.. in the A (for Audio) column... check that the drive is set to RECORD.
Rail
Ok this may be a really stupid question (and probably is), but where is the workspace window (yes i should read the f'ing manually but I don't have it with me and won't have access to it for a few days. Thanks for the input so far
KP A+, MCP |
You can't daisy chain a hard drive in the 002 extra port. Did I say that already?
Top menu bar>windows>show workspace The audio drive should be set to "R" good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Thanks, that was what I was looking for.
-Kevin
KP A+, MCP |
Just so everyone knows, It does work, to prove it I set 18 tracks to record and left it running for 30 minutes, when I came back it was still running, I figured that was good enough for me. Thanks for all your help everyone.
-Kevin
KP A+, MCP |
You CAN daisy chain via the second port !
For the record, it may be interesting to note the following:
- I was also under the impression that you couldn't use the second firewire port of the 002. However, for those of you that may have recently bought a Lacie D2 external drive, you will soon realise that the Lacie only has one firewire port (unlike some external drives which have 'A' and 'B' (i.e. two) firewire ports for chaining devices). This means that if you are using a Powerbook, for example, with only one firewire port and two external drives, you are obliged to connect the lacie to the digi as the last device in the chain. Which I did....and it works just fine! |
Kevin, I also have the Bytecc firewire enclosures and I have had my external drive unexpectly switch the workspace designation twice: once to "playback" and once to "transfer". I have no idea what causes it. The first time I actually moved my audio files and reformatted the HD. The second time, I looked for and found the "workspace" solution.
I would be interested in finding out how a HD can switch from Record to "Transfer or Playback Only." Is there any combination of CTR or ALT that can do this?
John-Q6600,GA-EP35-DS3P, Zigmatec S1283: 235 D-Verbs @ 2.4 ghz |
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there | huncke | Pro Tools TDM Systems (Win) | 6 | 02-23-2010 02:06 PM |
Laptop not recognizing external hard drive | RichrdC | Pro Tools M-Powered (Win) | 0 | 02-21-2010 09:18 AM |
Valid Audio Drive (hard drive issue) MacPro / HD3 | owenpop | Pro Tools TDM Systems (Mac) | 5 | 01-11-2008 12:28 PM |
iMac not recognizing Glyph hard drive | Hopeless and Reckless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-29-2005 10:42 AM |
Hard Drive Performance Dual Processors and Dedicated Audio Drive | j_jayzatuc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-03-2000 05:52 PM |
