PT Not Recognizing My FW Drive ---- Please Help!
Hello.
So I've been using two Lacie drives (one for audio, one for backup) with no problem for months. Yesterday I defragged the drives and now PT won't open any of the sessions. It says there's a problem with the drive allocation, and then if I try to reassign the audio files to the FW drive it says it's not an audio volume. What the hell did I do? On another note, I called Digidesign and after navigating very irritating menus a recording told me they were too busy and to f-off. THAT is irritating. Thanks very much for any help! Just Nick |
Re: PT Not Recognizing My FW Drive ---- Please Help!
Find the menu "show workspace" maybe its under windows, etc. You will see that all the drives are labeled with T, R or P . Transfer, Record, or Playback. You can change it (its alt-click or ctrl-click or right click or something) to make your FW drive "R - R". That will do the trick. it must be a Record volume. Also I disable write caching in windows and the drive is more stable.
I would give you more specifics but I am at work and not in front of PTLE right now. That should do the trick. -Justin
5198 Studios |
why is my pc not recognizing my external drive???? | Livin' Proof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-10-2006 06:32 AM |
PT not recognizing Hard Drive as audio drive | Kevin P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-20-2004 08:52 AM |
Waveburner Pro not recognizing FW drive | picksail | Pro Tools TDM Systems (Mac) | 13 | 07-27-2003 04:45 PM |
Protools not not recognizing drive | jeffm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-31-2003 08:00 AM |
PTF not recognizing CD-RW Drive | Driven01 | Digidesign Hardware & Software | 2 | 12-28-2001 11:32 AM |
