Old 12-27-2015, 04:11 PM
jsbach jsbach is offline
Default "Missing Files" when using Track Freeze in sessions made prior to 12.4?
Track Freeze is working great when using it in a completely new session, however when I freeze a track in an older session (one made in a version prior to 12.4) I get the "missing files" dialog the next time I open the session after saving.
Is anyone else experiencing this?
Old 12-27-2015, 05:17 PM
Shan's Avatar
Shan Shan is offline
Default Re: "Missing Files" when using Track Freeze in sessions made prior to 12.4?
This could be a development oversight or bug do to the recently new Rendered Audio Files Folder which saves the frozen audio. Some testing on this should be done. What version exactly was the older session made in? Thanks.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 12-28-2015, 05:52 AM
Shane
Thanks, Shane.
I don't remember the exact point release when the older sessions were created, but I was testing on sessions made with previous versions of Pro Tools 11 and 12. I'm currently on OSX 10.11.1 if that info helps as well.
Old 01-13-2016, 01:38 AM
Ljudit Ljudit is offline
I have kind of the same problem. I usually make a new copy of my project every day to be able to go back to an earlier version. The missing files happens if I unfreeze tracks in an earlier version and then open my latest version. The freeze files has been removed and even if there is no freezed tracks in the later project version Pro Tools warns me of missing freeze files. And I can't find a way to manually remove these freeze files from the project.
A good thing thou is if I unfreeze tracks in a project and then open an earlier version of that project Pro Tools didn't remove the freeze files and the tracks is still freezed
Old 01-13-2016, 01:48 AM
Jon_Atkinson Jon_Atkinson is offline
The last few days I've been sorting out a bunch of sessions from a few months back (all created with PT10.3.4), and going through and rendering some files, and also using the Freeze function... No problems at all here...
But I went straight from PT10.3.4 to PT12.4 if that's any help?
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 11.6.1
Protools Studio 2023.6
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 01-13-2016, 03:40 AM
Tim R. Tim R. is offline
The only time I've run into missing freeze files (so far) is when I opened a 12.4 session (with frozen tracks) in PT11 then DIDN'T save, then reopened in PT12.4 and all frozen media was gone. I had to unfreeze and refreeze to remedy the situation.
Tim
Tim Reisig
Main System: Pro Tools Ultimate 2022.20, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2022.12 (no Hardware), Mac OS 13.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 01-13-2016, 05:59 AM
Tim
Could be what happened to me but I'm not able to regenerate the freeze files. Nothing happens if I select "regenerate missing rendered files without searching". The tracks is already unfrozen so when I freeze it again PT just makes new freeze files an continues to warn me about missing files
Pro Tools HD 2018.1 | HDX | HD OMNI | S3/Eucon 4.0.3 | Mac OSX 10.12.6 | Mac Pro 2013 | 64 GB RAM
PT12 - "freeze track" feature Dave Lang Pro Tools 12 52 01-29-2015 08:05 AM
offline bounce from Send or Track outputs - track "freeze feature" OliverH Pro Tools 11 20 05-25-2014 04:45 PM
The input path "S/PDIF L-R" was made inactive because its stem is missing. ampnerd macOS 3 02-05-2014 08:58 PM
Freeze when "Some paths were made inactive..." message appears (10.3.6) SlicerSounds Windows 1 07-07-2013 10:20 PM
"Missing audio" when moving sessions from G5 to Glyph Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-01-2010 02:30 PM
