Hello.
I just recently purchased an M-Audio MobilePre with Pro Tools SE so that I could start recording directly from my guitar. I am able to record with the guitar just fine. And I am capable of selecting notes in a MIDI session to write a little bass part with a synth to go under it. Now I want to add drums. So I opened a new instrument track, and chose a drum kit, but now whenever I open the MIDI window, it still shows the synth part I wrote and the "Inst 1" label at the top. How do I change this to "Inst 2" so that I can place some drum parts? Note when I say MIDI, I mean the virtual keyboard on the screen is all I am using to write these simple parts. I do not have any real keyboards plugged in. Thanks. |
In Mix or Edit window, double click on the name of the track (doesn't matter what type of track it is) and rename it to a more descriptive name. It is best practice to give each and every track in a session it's own distinctive name.
In the Midi Window, to the left you should see a 'Tracks' list. Select which track you want to edit and go to it. Select midi Merge button on transport if you want to record non-destructively....that is to say adding Midi whilst keeping what is already there. If Midi Merge is not engaged, existing Midi will be replaced.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Selecting instrument or midi track automatically arms record | tunes7 | Pro Tools 10 | 4 | 05-03-2013 02:51 PM |
Instrument track issue, hear midi notes,but wont record | siga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-19-2012 02:11 PM |
Instrument Track won't record MIDI | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-19-2009 12:20 AM |
MIDI to Instrument track record | DonaldM | MIDI | 5 | 05-07-2008 03:57 PM |
