Old 07-06-2011, 09:53 PM
runningdreams runningdreams is offline
Default Help with Octopre connection to Pro Tools HD
Hello,
I have just purchased an Octopre Platinum mic pre and need to hook it up to my Pro Tools HD system. What is the best quality connection to use and what kind of cable do I need to get?
Thanks for any info you may be able to provide.
Rachel
Old 07-07-2011, 02:07 AM
Andi R Andi R is offline
Exclamation Re: Help with Octopre connection to Pro Tools HD
get an analogue Sub D to Sub D Cable.
then connect the Line Output of your Octopre to the analogue Input of your 192.
http://shop.avid.com/store/product.d...88865114072816
hope that helps!
ReRecording Mixer & Venue D-Show Live Sound & Recording Engineer
www.audio-machinery.com
Old 07-07-2011, 04:36 AM
Default Re: Help with Octopre connection to Pro Tools HD
Hi Andi
Thank you for your reply. This sounds good. Would this be the best quality cable and connection? I have the 25pin AES/EBU cable that came with the 192. I tried plugging the pin into the octopre output and then the 4 male xlr cables into the pro tools xlr inputs 1-4 but could not get a signal. Shouldn't this work? Do I have to configure my I/O a certain way?
Thanks.
Old 07-07-2011, 05:07 AM
BradLyons BradLyons is offline
Originally Posted by runningdreams View Post
Hi Andi
Thanks.
AES/EBU and XLR look the same, however they are not. In fact there are even (2) protocols for wiring within each AES/EBU and XLR DSUB snakes where the wiring could be reversed. What I mean is that there's a TASCAM FORMAT and YAMAHA format that the industry follows---two for multi-channel AES and two for multi-channel Analog. Now let's say you were to go AES/EBU out of the Octopre using their AES option.... and AES into the 192..... this wouldn't be the best connection because the converters on the Octopre are NOWHERE near those of the 192I/O interface. In this case, analog is better as suggested---- You need an analog DB25 to DB25 snake that follows the TASCAM protocol. Basically, this is MONSTER, MOGAMI, LIVEWIRE, PROCO, etc. Do this, you'll get the best results---and be just fine.
Thank you,
Brad Lyons
www.howavl.com
Old 07-07-2011, 05:21 AM
exactly as Brad said.
and just see the avid shop link!
Old 07-07-2011, 05:13 PM
Brad
Thanks a lot for the info. I ordered the cable today and it will be here tomorrow.
I'll certainly keep your contact info if I need to get some new gear in the future I'll give you a ring.
Andi
Thanks also for the info on the right cable and the link; that is the cable I ordered.
Best,
Rachel
Old 07-08-2011, 07:00 PM
hope that helps!
I have hooked up the sub d output of the Octopre into the sub d analog input of the 192. I am new to this so need some help. How do I get a signal now through the Octopre? Do I need to configure my I/O setup a certain way? Do channels 1-8 on the pro tools correspond to ch 1-8 on the Octopre?
Thanks for any help you can offer.
Rachel
Old 07-08-2011, 07:48 PM
Never mind! I have everything working now. Thanks!
getting a hiss when connected octopre mk II to Pro tools 8 teketuco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-28-2012 03:40 PM
PT LE 8.0.3, Digi 003+, Octopre MKII ADAT connection Jay_dammit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 03-11-2010 07:03 AM
003R+ rack with octopre VS Focusrite Octopre x2 through M-audio Lightbridge Sweepxcore General Discussion 12 05-24-2009 06:44 PM
Mc Mix and Pro Tools 7.4 bad connection pokypok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-12-2008 09:49 AM
Pro Tools Loses connection with 002? please help. joeH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2005 12:26 PM
