Old 01-07-2007, 12:08 AM
soundboy35 soundboy35 is offline
Default Reason as an Instrument Track
When I'm using Reason as an Instrument Track, I can record my notes, hear the sounds, and the notes will appear in the MIDI track, but the track is greyed out and there is no sound on playback?
In Reason, I do not use the 14 x 2 mixer, but instead use the 64 outputs directly to Pro Tools, so
in the Instrument track I assign Reason, and use its output 13, as well as output 1-2 of PT. I had read somewhere that you have to assign some kind of input on the track (A1, A2, etc) but this does not seem to make any difference. Anything else like Xpand will work fine...am I missing something?
Steve
PT HD 7.2.1
G4 1.2ghz
OS 10.4.7
MacBook Pro 15in, 2.3gHz,i7
PT 20.9.1.123
PT12.8.x
Old 01-07-2007, 05:39 PM
Brad Ryan Brad Ryan is offline
Default Re: Reason as an Instrument Track
Haha.. just went thru this today..
Instruments tracks are cool, funky new things
On the instrument track with Reason on it make sure you set your view to show instrument (edit/mix window shows instrument).. In that view there will be an output assignment to reason, whatever virtual machines you have open in reason will show up here.. select the one you want and bingo..
have fun
-Brad
Brad Ryan
www.candcstudios.net
Old 01-07-2007, 05:48 PM
TCDet TCDet is offline
Quite a bit.
I hope this helps:
Rewire reason-outputs all need their separate inputs (Aux's) inside of Pro Tools and / or separate record tracks (input enabled) to hear all you've patched.
An instrument track is a hybrid aux and midi track combo. If it is grayed out than your not midi-connected to an instrument. (i.e. Subtractor ect...) (View Instrument column in PT’s)
If your hearing-control of reason with no Pro Tools midi / instrument tracks record enabled then your Reason preferences and sequencer need to be disconnected from your midi controller.
Use the mixers in Reason to monitor your reason sounds.
Use the Reason Audio Splitters and set up discrete outs to Pro Tools inputs for tracking.
A perfect place to have templates constructed for it is a bit of patching.
Instrument Track MIDI playback Issue with Reason djcrypto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-29-2013 07:11 PM
sustaining one instrument track while the second track is not sustained with foot ped nrsjunkmail777 MIDI 0 09-28-2011 06:58 PM
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
Mono Instrument Track VS Stereo Instrument Track mbox2issue Tips & Tricks 8 04-20-2009 04:21 PM
Reason as an Instrument Track soundboy35 MIDI 3 01-07-2007 01:13 AM
