Is there any trick to getting a Pro Tools 882/20 and a 888/24 to both run on a Mix TDM System? Do you have to have the 888 as the master or does it make a difference? I used to have 2 882's but swapped one the 2nd 882 for a 888 so I could record at 24 bit. Any help would be greatly appreciated. Thanks. Russ
I would use the 888/24 as the master and the 888/20 as the slave. Then you go and trash the Pro Tools & Digisetup prefs. Empty the trash and restart your computer. Then launch Pro Tools. It will then ask to select your Hardware. Your done.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
You will save one DSP chip connecting both with an Y cable.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Your system still thinks it's talking to 2 882's. You need to reset your device selection by deleting the digisetup pref file, reboot, when you restart protools it will ask for your new hardware IO settings. You can use the two devices in either order. If you have an external clock I would use that for 256x word, otherwise use the 888 as the master clock. I believe the clock on the 888/24 is better than the clock on the 882/20, although I wouldnt' place a bet on it. The good part of having both devices is that you can use the 882/20 for CD and -10 IO and the 888 for +4 IO as well as utilizing the analog and digital outs simutaniously on the 888.
cheers geo
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
002 connection issue | Keniko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-22-2014 09:45 AM |
Pro tools mbox 2 connection issue. | eli_crow | macOS | 0 | 03-05-2011 02:38 PM |
Mbox2 Pro - Connection issue | Megnus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-04-2010 02:32 AM |
002 Rack Connection Issue | Trifektor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-27-2008 10:20 AM |
Mbox connection issue... XP | borednbuzzed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-12-2003 06:32 AM |
