Old 01-18-2000, 03:26 AM
Philee Philee is offline
Default PT5, Magma, G4
I'm trying to run PT5 mix plus on G4 350 Mhz with magma 7 slot chasis. Somehow G4 dosn't recongnize magma chasis. Don't remember exactly but after PT5 installation the computer screen shows DAE can't create something (no 'error number' sign though). I used a test program that came with magma. But it shows computer can't detect any cards. I installed cards in proper order. Is G4 not compatible with PT5 and magma? your help is greatly appreciated.
Old 01-18-2000, 06:24 AM
tombi tombi is offline
Default Re: PT5, Magma, G4
It IS compatible. I'm running the same setup. Maybe the problem is your card config in the computer. Have you installed the Magma host card in the same slot the manual states?
If it doesn't work I can write down my config.
/T
[This message has been edited by tombi (edited January 18, 2000).]
Old 01-18-2000, 08:59 AM
Thanks combi. What do you mean by manual state? Could you please tell me your system's configuration? I have G4, magma 7 slots, adaptec acceleration card, and PT5 mix plus. Magma includes core, and farm cards. I put a core card closest to the power supply (#4 slot). And the farms next to it(#5, 6 so on). By the way do I have to initialize hard disks with certain programs such as FWB? Also tech support please help me, why do my screen shows 'DAE can't create' after installation of PT5?
Old 01-18-2000, 10:52 AM
Eric Hector Eric Hector is offline
Hi
You should put the Magma chassicard closest to the
powersuply then the core and farms.
Make shure that it is the right Magamacard in the chassi.
Good luck
/Eric
[This message has been edited by Eric Hector (edited January 18, 2000).]
Old 01-19-2000, 03:52 AM
Exactly Eric.
My Magma (left to right):
Host card
Mix Core
DSP Farm
Extra monitor card
My Computer (1-4):
Monitor
Chassi cable
DC-30 Video Card
SCSI-Accelerator card
Works excellent. I think the big thing is to have the Host Card closest to the Power supply in the chassi as Eric wrote, otherwise the G4 won't recognize the Magma.
/T
[This message has been edited by tombi (edited January 19, 2000).]
Old 01-19-2000, 08:28 AM
it must be the farm card. I did installed host card closest to the power supply but no avail. Also in the order of graphic, magma , and scsi accelerator card. Now the computer keeps crashing. Something must be wrong.
Old 01-19-2000, 09:48 AM
Corcharge Corcharge is offline
Philee-
I have achieved success with my Magma 7. The problem was due to a DSP (vintage)farm card in the Magma.I now have only mix core,mix farm and D24 cards in the Magma and all is well.FYI,I am also running an Adaptec AHA39160M card in the G4/400 with no problems.
Old 01-21-2000, 06:41 AM
DigiTechSupt's Avatar
It sounds like the "vintage farm" needs to be updated. There is a Large chip on the farm card that has the letters AMCC in large white type. On that chip there will be a number - something like 13479Q -
Unless it ends with "QC" or higher, like "QE" or even "QF" then it will not work in a chassis. Contact tech support to find out about how you can have your card upgraded to be compatiable. 650-842-6699
B Carter
Digidesign
Avid Audio Tech Support
Support FAQ
Any knowledge of this Magma....magma p7rb 64 bit ? Sixstringer7 Pro Tools TDM Systems (Mac) 5 04-02-2011 02:39 PM
PT9: Magma & PCI Mount Royal Pro Tools TDM Systems (Mac) 0 11-18-2010 11:31 AM
7.4.2 and MAGMA p4tw Pro Tools TDM Systems (Mac) 0 06-21-2008 12:40 PM
G4/550 001 and Magma jtrolka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2002 01:43 PM
5.1 w/Magma? flymax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-05-2001 07:43 PM
