Re: 2021.6 Colours are different
The preset buttons are actually saved settings. You'll see them listed as Quick Preset in the same Color Palette settings folder.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 07-01-2021 at 12:06 AM. Reason: typo |
It's a small thing, but it IS irksome.
Neotech Concepts http://www.imdb.com/name/nm0235036/ ! sonic gymnastics for the illusionary arts ! 2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch, EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB |
There’s got to be a way for them to get the header color to match the strip color like before. Seems like a glitch to me. It bothers me too.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Yes, if you trash prefs the UI Customization parameters will be reset. So, it's definitely a good idea to save your custom settings as a preset file. But, note that presets 1-5 exist as "Quick Preset 1.ptpreset", "Quick Preset 2.ptpreset", etc in the same preset folder location. So, these 1-5 assignments will be retained even after trashing prefs.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
I should also mention this article in case any of you have issues saving Color Palette presets:
https://www.pro-tools-expert.com/hom...-we-have-a-fix
#16
Personally I would have been thrilled to keep using the 2020.12 dark mode colour scheme. I really loved it, I found it sleek and visually pleasing and I'm really having trouble adapting to what feels like a much more chaotic setup now, even with all the wacky customization options. Especially the clip highlighting (the inversion and the white line around the selection) I'm really hating in the second iteration of dark mode, the extremely aggressive contrast between what's highlighted and not. I would have stayed with 2020.12 but the "real time threads" option seems to have eliminated some playback errors I've been having since leaving 2019.6. My vote is firmly in allowing for 2020.12 dark mode again. Oh and the UI Customization menu hanging off the bottom of the Colour Palate really mucks up my view of the top right of the screen where I normally keep that window floating. Hopefully that gets moved somewhere less obtrusive... This all really feels like a "kitchen sink" approach vs the much more refined 2020.12 dark mode. And maybe the worst thing is that the grid lines are a lighter colour than the background. It used to be the other way around (the grid lines were darker), that was a lot easier on the eyes. I tried adjusting the grid line brightness down but it doesn't go far enough to make it darker than the background. Especially inside clips those with all the grid lines the same brightness (before it was darker outside a clip and lighter inside) there's less distinction between clips and track. The clips seem masked by the grid lines. I noticed the grid brightness slider only goes down to 35 so maybe being able to go below that would be a solution. For now I can only stand to look at the timeline in slip mode. This stuff really wasn't broken before was it? I'm also disappointed that if I go to other studios there is yet another little setting file I have to load into the depths of that system to get it to look right, rather than a standardized dark mode... a la 2020.12... Ok enough ranting. Also the orange volume lines for uncoloured VCAs were really nice the grey is ugly.
#17
Unfortunately you are deeply in the minority here. Many hated dark mode altogether. The ones that preferred dark mode wanted desperately to modify it for easier reading. Almost everybody wanted the option to adjust the colors to their liking, hence Avid listened and provided such functionality. This is the first iteration of this functionality, so there are areas of improvement. What seems like chaos to you, may be exactly what is needed to customize the UI that suits another.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#18
Not to mention the purple elephant in the room,,,,,,everyones color and contrast "perception" can be from slightly, to sometimes dramatically different (depending on their specific DNA)
So it's very much a matter of different strokes for different folks . Personally I really like header color being more pronounced Between the new color pallet adjustments and musicman 691's modded file, I am happy as a clam at high tide .
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
#19
Thank you for bringing this up. This drove me nuts for the few days I worked on 2021.6 ! The colors you select in the palette no longer correlate to the colors on the actual tracks.
#20
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 07-06-2021 at 05:54 AM. |
2021.6 and 2021.7 restart after exit | NJsound.com | Pro Tools | 12 | 08-11-2021 01:45 PM |
2021.6 colours? | midnightrambler | Pro Tools | 6 | 07-29-2021 08:47 AM |
Clip colours | Reckless Erik | Pro Tools 2018 | 0 | 03-07-2018 06:50 AM |
Memory Colours? | Neurosis | Pro Tools 12 | 2 | 06-12-2016 10:59 AM |
