Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 09-28-2021, 08:32 AM
wkdreskin wkdreskin is offline
Default Unrelenting clicking
Hi. Can't seem to persuade my PC to stop interfering with my recording and editing. Running current version of Pro Tools and I've followed all the optimization guidelines at https://avid.secure.force.com/pkb/ar...ndows-10-Guide. While I've got tons of software on my computer, I'm only running Pro Tools. Nevertheless, I hear intermittent clicking both when recording and when editing (appropriate adjustments to buffer size for each). Here are my specs. Anyone have a thought? Thanks in advance!
OS Name Microsoft Windows 10 Home
Version 10.0.19043 Build 19043
System Manufacturer Dell Inc.
System Model XPS 8900
System Type x64-based PC
Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 4 Installed Physical Memory (RAM) 64.0 GB
Old 09-28-2021, 09:24 AM
climber climber is offline
Default Re: Unrelenting clicking
I don't see an interface listed?
sounds like it could be a clocking issue...
Al Hospers
bass, vocal, composer, engineer
CleverSounds Recording
OS X Catalina, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2021, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 09-28-2021, 09:34 AM
JFreak's Avatar
JFreak JFreak is online now
Compatibility info here.
Janne
Old 09-28-2021, 10:25 AM
Interface is Focusrite Scarlett USB. Thanks.
Old 09-28-2021, 10:27 AM
As for compatibility, I'm using Windows 10 version 21H1 and Pro Tools 2021.7.0.
Old 09-28-2021, 10:54 AM
The Weed's Avatar
The Weed The Weed is offline
Run LatencyMon for 20 minutes or so to see what is causing the issue.
If there are no red flags with LatencyMon, then it may be a clocking issue.
Make sure in Control Panel>Sound that your onboard soundcard is the default for Windows Sounds/Audio on both the Playback and Record Tabs and disable any instance of your Focusrite. Then make sure the Pro Tools session and the Focusrite are using the same Sample Rate.
Also have a look at this Thread and do a search for Processor Affinity.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-28-2021, 04:17 PM
Just want to say thanks for all of these ideas. It's a preliminary report but, so far, the clicking seems to be gone.
Billy
Old 09-28-2021, 04:45 PM
The Weed's Avatar
For anyone else who might have issues and finds this Thread, what cured the clicking?
Old 09-28-2021, 05:13 PM
I think that separating out the Windows sound card from the Focusrite may just have done the trick. Someone mentioned using their Mackie One Knob, which I also have, and that allowed me to place an A/B switch for the cards.
Thanks again!
Old 09-28-2021, 07:14 PM
kobi_dog kobi_dog is offline
could be a wall socket loop thing? when it clicks is the fridge or something else turning on?
Try a new wall socket for your power, could be on a loop?
Clicking! MindDead Pro Tools 12 2 12-30-2015 06:23 PM
DB-33 clicking omnipop Pro Tools TDM Systems (Mac) 7 02-09-2009 12:06 PM
clicking and clicking... nostranger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-21-2006 09:24 PM
clicking? TonyGoolah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 12-27-2005 12:23 PM
THANK GOD THE CLICKING IS GONE. stickstome2 General Discussion 0 01-24-2001 07:56 PM
