Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 09-28-2021, 07:54 AM
midnightrambler midnightrambler is offline
Default Anyone else struggle with this? "Instruments Out"
This just looks like a mess to me. Most of these aren't even VIs and I'm never going to use MIDI to automate an EQ. Such a major headache just to find a sample trigger. Maybe it's bad management on my part...
Old 09-28-2021, 10:33 AM
johnsimmons johnsimmons is offline
Default Re: Anyone else struggle with this? "Instruments Out"
yes it's a pain since Fabfilter and a few others are creating midi nodes (if that is the correct term) to control features on every plugin so you get a huge dump of midi routing. I don't think this can be disabled.
Only workarounds have been to label the track like AAA or XXX or something that catches your eye and ends up at one end of the list or the other.
I also have reported that I believe this too many nodes is part of the problem where sometimes deep into a session you can't correctly point a midi output to a plugin or outboard external - it always "jumps" and selects a random output. happens a lot but i can't reproduce it in a series of steps (yet)
Old 09-28-2021, 05:23 PM
Eric Lambert's Avatar
Agreed, these are annoying, and FabFilter is the most common offender in my studio. It's not been a showstopper but it would be nice to be able to turn off the MIDI registrations within certain plugins.
Old 10-01-2021, 07:27 AM
Thanks for the replies. I've created a "User Setting" that unticks "MIDI enabled" in the Q3, hopefully that might bring the list down a bit in future? Worth a go anyway I guess.
Old 10-02-2021, 12:07 PM
Good idea.
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Error 7401 with EastWestQL's "Play" and Virtual Instruments [solved] Skybreak Pro Tools 10 8 01-15-2013 12:25 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
