Old 08-29-2021, 08:12 AM
sriks sriks is offline
Default Re: Dolby Atmos Panner
I found the log file, and this is what I see/
2021-08-29 11:08:39 INFO comms_connection_server - listing on port 4826
2021-08-29 11:08:39 INFO MasterFileView - Opening master file: /Users/studio1234/DDATM-MIX/Xz/Xz.atmos
2021-08-29 11:08:39 INFO RendererExecutive - -------------------------------------------------initializing--------------------------------------
2021-08-29 11:08:39 INFO Scheduler - Running scheduler with #7 threads
2021-08-29 11:08:39 INFO RendererExecutive - Total latency in samples: 1058
2021-08-29 11:08:39 INFO RendererExecutive - Started audio driver with 512 frame size at 48000Hz
2021-08-29 11:08:39 INFO RendererExecutive - ---------------------------------------------------- DONE -----------------------------------------
2021-08-29 11:08:39 INFO RendererExecutive - uninitializing
2021-08-29 11:08:39 INFO CommsServerPublisher - Commslib 3.0 server service published
2021-08-29 11:08:40 INFO RendererExecutive - -------------------------------------------------initializing--------------------------------------
2021-08-29 11:08:40 INFO Scheduler - Running scheduler with #7 threads
2021-08-29 11:08:40 INFO RendererExecutive - Total latency in samples: 1058
2021-08-29 11:08:40 INFO RendererExecutive - Started audio driver with 512 frame size at 48000Hz
2021-08-29 11:08:40 INFO RendererExecutive - ---------------------------------------------------- DONE -----------------------------------------
2021-08-29 11:08:52 INFO MasterFileView - Arming record
2021-08-29 11:09:55 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:09:55 ERROR AudioEngine - TC discontinuity. Expected: 175443096 actual: 175443608
2021-08-29 11:10:24 ERROR RendererExecutive - Audio device underrun
What does Audio Device under run means here? my audio interface is AVID-OMNI-HD
Independent Music, where raw passion and untamed creativity meet and thrive, a refreshing departure from the mainstream.
https://dfyus.bandcamp.com
https://www.youtube.com/@Srikanthd
Old 08-29-2021, 08:18 AM
creativecontrol's Avatar
I would start here with regard to optimizing the resources you have on the 2013 machine:
https://professionalsupport.dolby.co...language=en_US
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-29-2021, 08:55 AM
gives's Avatar
gives gives is offline
Jeff
Jeff is right. This is one reason I went with a full complete upgrade of my room with the best equipment available. I still have a Late 2013 Mac Pro, but it has not given me any trouble with everything else I have upgraded here and will buy a new Mac Pro once I see where that is going. I also stayed on Catalina and it's running perfectly. I takes some time to get things all going and Jeff Komar know this all too well-:). G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 08-29-2021, 09:03 AM
No Luck, I tried all the possible combinations from that help website.
I am still getting "Audio device underrun" in the Renderer Log, I do not think Renderer has been tested well by Dolby. I do understand it is a complex piece of software, however if they had told me about these under-run issues I would have stayed away from it. I called protools help line, they punted to the Dolby, and I do not have number to contact Dolby. I think I am stuck! at this time, which is sad, I have promised my client to produce an atmos song track. It is now under jeopardy i guess. hate it when Avid goes silent on know issues.
2021-08-29 11:54:38 INFO RendererExecutive - -------------------------------------------------initializing--------------------------------------
2021-08-29 11:54:38 INFO Scheduler - Running scheduler with #7 threads
2021-08-29 11:54:38 INFO RendererExecutive - Total latency in samples: 1058
2021-08-29 11:54:38 INFO RendererExecutive - Started audio driver with 512 frame size at 48000Hz
2021-08-29 11:54:38 INFO RendererExecutive - ---------------------------------------------------- DONE -----------------------------------------
2021-08-29 11:54:45 INFO MasterFileView - Creating master file.
2021-08-29 11:54:45 INFO MasterFileView - Arming record
2021-08-29 11:55:57 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:55:57 ERROR AudioEngine - TC discontinuity. Expected: 175846781 actual: 175847293
2021-08-29 11:56:00 INFO RendererExecutive - uninitializing
2021-08-29 11:56:01 INFO RendererExecutive - -------------------------------------------------initializing--------------------------------------
2021-08-29 11:56:01 INFO Scheduler - Running scheduler with #7 threads
2021-08-29 11:56:01 INFO RendererExecutive - Total latency in samples: 1058
2021-08-29 11:56:01 INFO RendererExecutive - Started audio driver with 512 frame size at 48000Hz
2021-08-29 11:56:01 INFO RendererExecutive - ---------------------------------------------------- DONE -----------------------------------------
2021-08-29 11:57:06 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:57:36 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:58:05 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:58:35 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:59:07 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:59:11 INFO MasterFileView - Arming record
2021-08-29 11:59:34 ERROR RendererExecutive - Audio device underrun
2021-08-29 11:59:34 ERROR AudioEngine - TC discontinuity. Expected: 173537620 actual: 173538132
2021-08-29 12:00:04 ERROR RendererExecutive - Audio device underrun
2021-08-29 12:00:34 ERROR RendererExecutive - Audio device underrun
and when I try bouncing (ADW BWF) directly from Protools, Pro tools throws an error (enclosed)
File Type: png Screen Shot 2021-08-29 at 12.05.17 PM.png (76.9 KB, 0 views)
Old 08-29-2021, 09:16 AM
I am still running High Sierra 10.13.6? should I upgrade to Catalina?
Will AVID OMNI-HD work on it? I have tons of plugs-in etc. I am really nervous to upgrade. Should I? will it fix this buffer under run?
  #16
Old 08-29-2021, 09:26 AM
its2loud its2loud is offline
If you're running High Sierra I would suggest meticulously backing everything up and upgrading to Catalina.
It's no surprise to me that you're having issues running Pro Tools 2021.7, Dolby Renderer, High Sierra, on a 2013 Mac Pro.
Even if you upgrade your mileage may vary at times.
One thing you could try doing is Commitng all your tracks in Pro Tools so there is absolutely zero processing for any plugins.
Create a new session with just audio for your source tracks.
Simply let Pro Tools be a playback of your rendered files.
See if you notice any difference in performance.
  #17
Old 08-29-2021, 09:27 AM
gives's Avatar
I totally stayed away from High Sierra, I went from Sierra to Mojave. Then I was told by Avid, (Jeff Komar), so upgrade to Catalina asap..I was a bit nervous, but it went really well this year in March. I had a lot of work, but did not have any issues other than the Movie Bounce issue, which everyone had with 2021.3, which has been more or less resolved well. I would also make sure that you understand that 32 bit software in Catalina going foward in OS X will not run any 32 bit software. Ex. Older MS Word, QT Pro 7 if you use it..etc. Just wanted to say that. I have not really missed either one, but good to know. I actually BTW did NOT do a clean install, but had no issues. I usually run Disk Utility first to check the internal Mac HD in Software Restore mode. Also then did the update. Also you may need to trash your PT prefs, if you have not done already. The set everything up again. Take a lot of screenshots of PT, Dolby Renderer so You have all of your ducks in a row in case you forget your setups in Dolby Renderer, but that should not be really affected.
If you are in the middle of this project, you may just want to advise the client that you are not able to deliver this project right now and just be honest with them until you get things more stable. I see you are still on 2021.r2? I would strongly advise you to update to the latest PT version if at all possible once you get things in a place to do so. 2021.7 is solid here as was, 2021.6.1
Good luck-:)
G
G
  #18
Old 08-29-2021, 09:31 AM
gives's Avatar
Yes I totally agree, I posted the same before I saw that its2loud did so.
  #19
Old 08-29-2021, 09:37 AM
gives's Avatar
So, how long did you run tests of this setup before taking on a project like this? Did you have success prior in any way before moving to the project or projects at hand? I ran tests for a while to make sure things were solid here. Got a lot of good info on watching video webinars online too months back before the room was done. I know this stuff seems daunting, but once you get past this, it should be pretty solid. Dolby also has some Renderer updates coming that were announced a few days ago. Mainly for Silicon M1 Mac compatibility, but I suspect it may be more than that. They are due for some additional features.
G
  #20
Old 08-29-2021, 09:41 AM
G
Really?! Where did you see this? I'd love to read it.
Thanks
HTML code is On
HDX and Dolby Atmos ViciousLullabyz Pro Tools HDX & HD Native Systems (Mac) 7 08-13-2021 06:29 AM
Atmos Panner for Pro Tools Control? Cheesehead Avid S1, S3, Dock and Control App 5 04-06-2021 05:37 PM
Dolby Atmos - Do I need SRC? budster Post - Surround - Video 4 03-24-2015 10:25 AM
Dolby Atmos subwoof Post - Surround - Video 3 09-11-2014 12:10 AM
Dolby Atmos mikevarela Post - Surround - Video 3 06-25-2012 07:13 PM
