Old 04-20-2013, 06:28 PM
cedub cedub is offline
Default how to change main.l and main.r
i'm new to pro tools.
how do i change the default routing for main left and right? It's set to my analog 1 and 2 outputs (for a motu 1224) and i want to change it to analog 7 and 8. i've been all over the I/O Setup dialog and i can't figure it out.
thanks!
Old 04-20-2013, 07:15 PM
Top Jimmy's Avatar
Default Re: how to change main.l and main.r
thanks!
I/O setup is the place to do it. Make sure you have all the ins and outs enabled in the MOTU hardware applet first. Then in the I/O setup, delete and default the input and output paths. Now you can rename the paths as desired and even rearrange them by dragging the L&R boxes for each path to the actual desired hardware ins and outs.
Buttdialed by me & Tapatalk
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 04-21-2013, 06:17 PM
zedhed's Avatar
zedhed zedhed is offline
Once you've got it sorted, don't forget you can rename I/O's to whatever makes most sense to you. The export function comes in handy here as if & when things go awry, just import the saved setup back & your good to go.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.3.2) Omni s/pdif w Eleven Rack
HD 96I/O
Win 10 Pro
Old 04-21-2013, 06:54 PM
awesome. thanks! i did try clicking the "defaults" button but i didn't delete everything first.
- cedub
Main Outs dmock66 Eleven Rack 13 06-03-2011 01:27 PM
Why does the output to amp selector change the main outputs? Hotcrazyfruit Eleven Rack 3 02-22-2011 06:06 PM
bad right main out? chahende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-20-2005 06:06 PM
Best way to wipe out main HD? Colorblind General Discussion 1 02-20-2004 09:56 AM
main outs vs. others freakuincy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2002 06:54 AM
