How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 09-26-2021, 07:10 PM
TattooedPreacher TattooedPreacher is offline
Default Apple QuickTime Install Mac Mini M1
So I have a Mac mini with the M1 chip and I installed PT 1st to see if it will work for me. Today I went to use it after a few months of non-use and now I cannot import .m4a audio files; getting the Install Apple QuickTime (which is installed). Iíve tried reinstalling PT and QuickTime but still wonít work. Is there another way to bring in audio files?
Old 09-26-2021, 09:03 PM
Top Jimmy's Avatar
Default Re: Apple QuickTime Install Mac Mini M1
Were m4a ever supported for direct import? I know wav, aif, sd2, and mp3 are/were, but Iím not aware of it ever directly supporting any other file types.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 09-26-2021, 11:32 PM
Sardi Sardi is online now
I think (itís been a while) Pro Tools can import an m4a file if itís encoded as AAC. I donít believe it can import an m4a file if itís been encoded as ALAC.
Itís kind of annoying as they use the same container (m4a) but are entirely different algorithms. Same as renaming an m4a file as m4r for their ringtone format. Same AAC encoding, but different file extension.
Again, itís been a while, but I do think you can import an AAC m4a file. I recall dragging in music from iTunes purchases years ago without converting. Not in the studio otherwise Iíd test it for you.
Old 09-27-2021, 02:00 AM
Hi, welcome to the community.
Some file formats are "broken" since Catalina and moving to 64-bit only. Also no video engine for Apple Silicon. We need to use workarounds for now.
Old 09-27-2021, 07:00 AM
its2loud its2loud is offline
Hereís a complete list of supported files as of PT 2021.6.
https://avid.secure.force.com/pkb/ar...e-Type-Support
What version of Pro Tools are running on your Mac Mini?
You can convert the file to .wav using Shutter Encoder
https://www.shutterencoder.com/en/
Old 09-27-2021, 08:04 AM
I exported my songs to .wav and was able to upload them into PT that way. Not sure why I thought I used .m4a files a few monthís ago. Thanks everyone for responding.
Old 09-28-2021, 05:40 AM
Stephen Bond's Avatar
I'm pretty sure m4as files would import into Pro Tools until recently. I have used them many times from my iTunes library.
I'm not running the latest Pro Tools so I guess the issue appeared in recent versions? I'm not running Catalina either but rather Mojave.
Stephen
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
Apple, QuickTime And PT GTBannah Pro Tools 2018 13 02-01-2018 09:33 AM
FS: Apple Mac mini 2012 quad i7 2.6 in Sonnet XMAC MINI SERVER rack Jamie Mac Buy & Sell 1 07-02-2017 11:50 AM
Apple Software Synth-QuickTime fdcfrank2016 macOS 3 01-28-2016 09:25 AM
Apple Quicktime 7.6 99ster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-05-2009 09:15 PM
