Zoom in follows playback head? preference?
Hi People.
Is there a preference or option to set PT so that when i ZOOM IN it Zooms in with the current position of the playhead centered in the window? so that zoom follows the playhead? thank you |
Re: Zoom in follows playback head? preference?
Hi.
It seems you can do this by clicking the small "a z" button in the top right corner of the arrange window immediately above the vertical scroll controls |
From memory, it should also be an option in the preferences.
Hey.
Replying to myself here, but i now seem to have lost the ability to zoom in on the current position of the play head, when PT is playing. Now im only able to zoom in on a finite point in time, which is the last point on the sequencer where i started playback from and is shown with 2 blue arrows pointing down. these arrows are also used to show the current region being looped in the playback window if loop is turned on. Does anyone know the preference to enable / disable this zoom follows playback position? thanks! |
Hey Guys
Still can't find how to reenable this feature.. can anyone help? thanks! |
"Link Timeline to Edit selection" enabled will focus zoom where the playhead head lands
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
Hi Richard.
Thanks for Replying. that doesn't seem to work for me. ProTools 11.3.1 with the Enable Keyboard Focus thing pressed |
bringing up this old thread, turns out I have the same problem, I work a lot in cycle playback mode, and it would be nice to have a way for the "r/t" keys to not just focus their zooming on the left locator. the only way to zoom to the right locator is to somehow shift scroll over to the right locator and press r/t again, but this only works when already zoomed-in so that the left cycle locator is not visible anymore, it's annoying.
link timeline and edit selection would make things easier for zooming, but it also changes the cycle locators to selection. meh..nobody here working with lots of loops or nobody making loops? if so, how is your zooming routine? I'm coming from several other daws, so I might be spoiled a bit in terms of workflow speeds.. |
Use left/right arrow keys to center start/end selection on-screen. That in conjunction with R and T and the Single zoomer gets a lot of use here.
Experiment with the various scrolling options as well. I think maybe Scrolling After Playback could be useful. The screen will center where you hit stop during (loop) playback.
ah thanks! it almost solves my problem, but when I zoom out enough that both down arrows are visible, pro tools automatically refocuses zoom to the left down-arrow, even if I made it focus the right one with your tipp of using the right arrow key - makes me a little dizzy - is there a setting to disable this maybe? still, the arrow key is pretty much a live saver for me, I used to make selections and then press opt+f and go from there which was slower :)
Bug - playback head gets stuck when zooming during playback | atucker | macOS | 0 | 01-18-2011 02:55 PM |
Preference question: Hearing audio during playback | audio[LAB] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-15-2007 07:23 AM |
playback head disappearing | Chris Julian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-05-2006 11:44 AM |
"Timeline Insertion Follows Playback" preference | WildHoney | Pro Tools TDM Systems (Mac) | 7 | 04-09-2006 03:42 AM |
"Zoom Toggle Track Height" preference is missing. | Stig Eliassen | Pro Tools TDM Systems (Mac) | 13 | 11-08-2005 02:46 PM |
