PT 9 novice
I've just bought and installed PT 9. I have one m-audio delta 1010 and one m-audio 2496. I used to run Cubase where all my inputs would be on the 1010 and for listening back I would use the 2496. When I first launched PT 9 it asked me to select a driver but it couldn't initialize the the m-audio delta asio driver, so I selected the Generic Low Latency Asio driver. Now I get an acess violation error when I try to load PT. I'm a bit miffed at it being such a faff. Cubase just always worked, but I appreciated that I'm new to it and I might just need some pointers. Any help is most greatfully recieved. Sandra report to follow. Sorry, should have read the Read this first, first. Here's Sandra SiSoftware Sandra Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : Purse User : Rich Processor Model : Intel(R) Pentium(R) D CPU 3.40GHz Speed : 4GHz Cores per Processor : 2 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : ASUS P5WD2-E Premium BIOS : AMI (OEM) 0604 07/10/2006 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR2 Chipset Model : ASUS 82975X Memory Controller Hub Front Side Bus Speed : 4x 230MHz (920MHz) Total Memory : 4GB DIMM DDR2 Channels : 2 Memory Bus Speed : 2x 173MHz (346MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : ATI Radeon HD 3400 Series (40 SM4.1 600MHz, 512MB DDR2 800MHz 64-bit, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Radeon HD 3400 Series (40SP 2C 600MHz, 512MB DDR2 800MHz 64-bit) Storage Devices WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 466GB (D:) OCZ-VERTEX2 (60GB, SATA300, SSD) : 56GB (C:) ADAPTEC RAID 0 407.5GB (RAID) : 380GB (E:) ASUS DRW-1608P2S (ATA66, DVD+-RW, CD-RW, 64kB Cache) : 7GB (F:) Disk : 4GB (H:) Logical Storage Devices Hard Disk (D:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) System Reserved : 100MB (NTFS) Data (E:) : 380GB (NTFS) @ ADAPTEC RAID 0 407.5GB (RAID) Hard Disk (C:) : 56GB (NTFS) @ OCZ-VERTEX2 (60GB, SATA300, SSD) 3.5" 1.44MB (A:) : N/A Pro Tools (F:) : 7GB (CDFS) @ ASUS DRW-1608P2S (ATA66, DVD+-RW, CD-RW, 64kB Cache) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627EHF/EF/EHG/EG Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semi High Definition Audio Audio Device : VIA M Audio Audiophile Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller Disk Controller : Adaptec Serial ATA II RAID 1420SA Disk Controller : Marvell 6141 SATA2 Controller USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MP640 series Printer (Colour) Network Services Network Adapter : Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x86 Windows Experience Index Current System : 3.5 Performance Enhancing Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Last edited by BaaMooUK; 06-24-2011 at 02:58 AM. Reason: Here's Sandra... |
Re: PT 9 novice
2 things that worry me:
ADAPTEC RAID 0 407.5GB (RAID) : 380GB (E:) Pro Tools doesn't support RAID. Pro Tools will only use a single interface at any one time(since PC users can't do the aggregate thing that Mac users can).
Re: PT 9 novice
Thanks for the suggestion.
I've read that elsewhere, but I used to use PT 6, + 7 and stored all the work on that drive. Besides, what would PT know anything about about raid? It's hardware raid, not software raid, and even the operating system only knows of single drive. So I don't think it's that. |
Novice in need of help | shandydash | macOS | 1 | 01-24-2013 05:55 AM |
help for a novice please. | c123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-16-2012 04:41 AM |
5.1 novice help | elcamino | Post - Surround - Video | 0 | 06-23-2005 12:37 PM |
Questions from a PT novice | soulextending | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-25-2004 05:12 PM |
Now know I'm a novice, but these acronyms!!! | SimpleNatureSpirit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-17-2004 10:04 PM |
