Anyone using Pitch N Time for LE?
Running PT 7.1 w/ Music Production Toolkit on a 002 and Tiger 10.4.8 I'm looking for a way to have not only the audio files processed in PnT, but also the automation (volume and f/x primarily...and having the markers move too would be great). I seem to always decide to change the tempo of my work DURING the mix...and I understand that the Digi Audiosuite architecture doesn't allow for the processing of automation. Would the upgrade to 7.3 (which would allow me to use PnT with the TC/E tool, instead of Audiosuite) solve my problem? Having the audio `shrink' without bringing all of my automation doesn't really work for me. Thanks, Steve |
Re: Anyone using Pitch N Time for LE?
Anyone????
I'm pretty sure you would need to go to 7.4, convert the whole thing to elastic audio, then change the session tempo.
Using PnT would be very messy if you had a lot of edits. Might sound better though. |
I don't think I'm entirely clear on what you're trying to do, so please expand a little on it if possible. But as the previous poster said, it seems like you will want to have 7.4 with elastic audio. Setting the audio tracks to tick will make them change with tempo automatically. And BTW, elastic audio sounds very good. |
I have tried to simply run my bounced mix through PnT as a stereo track, but the initial result was less than pleasant. I was only looking for a 5% increase in tempo, so that should be well within the logical boundaries of the plugin...right????? I'm really trying to avoid the 7.4 upgrade, since I would also need to upgrade my os from 10.4.8, and everything else seems to be ok. Thanks again, |
Looks like 7.4 it is (*!#$^*!!!)
The rest of my system is working fine! Upgrading my OS and jumping from 7.1.to 7.4 will surely be hell! |
PT7.4 is quite awesome, both in LE and HD. I have (2) HD systems, both of which I've held off on upgrading to 7.4. One system is for live TV broadcast and I don't want to mess with what's not needed to mess with, and the other I'm in the middle of mixing a large concert back in my own studio. However, I've worked with 7.4 here and the Elastic Audio is incredibly cool!!!!!!
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift | Franco1967 | Pro Tools 11 | 1 | 01-25-2014 11:31 AM |
Pitch n time on pt 10? Or what? | blankpro | Pro Tools 10 | 2 | 02-24-2012 01:51 PM |
PT8 - Pitch 'n Time LE and Time Shift - very slow to operate | Richard901 | General Discussion | 3 | 12-30-2008 09:00 PM |
Time Shift: Why no pitch/time strap?! | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-17-2006 05:44 PM |
Pitch 'n' Time?? | silence_of_stone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-20-2002 11:09 AM |
