Constantly Losing Communication with Command 8
just throwing this out there....I did a search first and nothing came up that resolved my issue. I have a Command 8, on a Mac Pro Dual 2.6 running PT|HD 2 ACCEL, v7.3.1cs7 and OS 10.4.9. I lose communication with my Command 8 maybe 6-8-10 times a day. To the point where I shut it off. I have reinstalled PT, trashed prefs and databases, I even replaced the USB cable. It is not plugged into a HUB. The only thing I can think of is the unit is self has a loose USB connection. Any Ideas before I call Tech Support? Thanks!
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: Constantly Losing Communication with Command 8
Ok, SO I found the V02.01.02 update and I ran that. I shut off unit and booted it up. We shall see if that solves my issue.
Ive had a buddy lose connection with a 002 rack unit because the "monster" firewire cable was so bulky that it pulled on the connection and it would lose communication. my 2cents
Studio Troll |
Are there any other devices on your USB chain? You might need a powered USB hub.
Thanks for the response. As I said in my first post, this is not going into a hub of any kind, but straight into the computer's USB connection. The other things attached are my keyboard, my midi interface (an M audio 4x4) and my ilok.
I have almost the same setup as you ... keyboard, ilok, Digi MIDI interface.. and Control 8. That is to many devices for the on board power in the USB chain to reliably handle. Griffin makes a good hub... can get you the model # if you like... only $30 or $40. Hope this helps... |
You might also want to try putting everything on the powered buss... ie: USB from Mac to hub, then USB 4 outs from the hub to your devices (keyboard, mouse/trackball, C|8, and MIDI interface). This setup is very stable and works great for me...
Best regards Ray |
Stating the obvious
Forgive me if I am, but have you set the correct channels in the preferences?
I would think that computer would have more than adequate power for those devices. I've got nearly the same machine - dual 3.0 - and have the same Midisport 4x4, iLok, Command|8 and Axiom keyboard and have never seen the C|8 drop offline.
Do you possibly have any wireless devices enabled or other software/utilities running in the background? Is there any chance the USB cable is getting knocked loose? I don't want to discourage you from trying a powered hub - the Griffin one that Ray recommends is excellent - however I do find it curious that this would be a USB power issue. |
002 lossing communication constantly | obol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-10-2007 12:09 PM |
002 lossing communication constantly | obol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-09-2007 11:59 AM |
002 lossing communication constantly | obol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-09-2007 08:01 AM |
Constantly losing contact with 002 Rack. WHY?! | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-13-2007 10:26 AM |
got 6.0.1 and STILL HUI losing communication | Tim R. | Pro Tools TDM Systems (Mac) | 11 | 04-29-2003 12:47 AM |
