Re: Asio driver problem !?
Good idea. Also, before your fire up any DAW programs, use the Device Manager control panel applet and make sure that your device shows up on the device list with no exclamation marks or other funny symbols. I believe that the devices must be listed under the "Sound, video, and game controller" tab to be available to the DAW. (I remember having them show up under a different tab and not being able to find them in the DAW program.) Right click on the device and make sure that the driver listed is the one you expect. Windows has to be happy with your device before you can use it in your DAW program.
Cautious optimism!
Apparently, this new driver requires a "new" approach. You install the driver with the unit OFF, re-boot, power the unit ON, Windows sees it and makes the connection. Thanx, Vonglahnpg!
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Is the same.
Sound Forge feeze the cursor, and Sonar don't work. |
PLEASE AVID
Help us ! |
Give us some information about your system. What Operating System etc.
#16
Thanks for any leads! |
#17
This sounds very similar to the problem I'm having with PT and my DM-4800 firewire I/O. Is it digital distortion that you're getting? I suspect that word clock is not communicating properly and thus your sample rate is not master / slaving correctly.
#18
I have the same problem. I also think it's a clocking issue. but I'm to blame (according to customer 'service'). It was my fault that I bought the 003. smh. I should have went with RME or anything else. Avid really sucks!
The problem is the ASIO driver, not my computer. I'm waiting for the class action. PT (003) is NOT compatible with windows 7. I don't think Avid is going to fix this, ever. It has been like this for 2 years. and not any attempt in fixing it. they tricked me for my money, well played Avid. |
#19
Im having problems with Asio too. I try opening any program ex, Mixcraft 6, Ableton Live 8, anything!. The second i click on Asio ( like using it to record ) every one of these programs crashes!. Updated the latest driver for my M-Audio Fast Track, my sound card updated as well, nothings working, everytime i click Asio it always crashes and gives me an error message!. Who has some advice on what to do?
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-19-2010 01:45 PM |
PRO TOOLS 7 ASIO DRIVER PROBLEM | instro001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-17-2005 07:57 AM |
ASIO / Wav Driver Problem (or maybe not) | jboaze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-28-2004 10:44 PM |
002 ASIO Driver Problem | shipwrecked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-15-2004 05:36 PM |
ASIO Driver Install Problem | splattstudio | Pro Tools TDM Systems (Win) | 9 | 11-05-2003 12:05 AM |
