I started a session mixing in surround, but I then switched to stereo (I need to burn a CD for a musician who doesn't have a surround system). I switched all my track outputs from surround to stereo. Yet I still have three chips used by the surround mixer!!
What exactly determines when the surround mixer is on, and how many chips it uses? [img]images/icons/confused.gif[/img] Thanks, Mike |
![]() Quote:
Best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Sonoma, PT Ultimate 2024.10.1. HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Rich,
(1) Is that the only way? I would sure prefer to leave the I/O setup alone, so it fits all needs and I don't have to ever worry about it. But if I must, I must. (2) Do you understand why 3 chips are tied up, rather than say 1? Thanks for the help! MIke |
It is probably due to using subpaths to the surround output for your stereo outs. This will still use the surround mixer. You can go to I/O setup and make a new stereo path and temporarily disable the surround path for the stereo mix if you need the extra processing. Do a Save As to keep the surround mix.
Gil Gowing Principal Digimidi Technical Services |
to clarify, what i've learned with huge amounts of trial and error is that ANY output/input/send that is a part of a surround path uses the surround mixer. so when you bus all your dialog to CENTER lets say (mono path) it all uses up a ton of surround mixer dsp because that mono path is a subpath of a surround path.
you can make a stereo aux input, and route all your tracks through a plain old stereo bus and then route that bus to the LR which is a subpath of your surround outputs. OR you could disable the surround outputs and enable some stereo ones. hope that helps and that it saves you all the time it took me to get this straightened out. -a- |
Thanks guys. This is a BIG BIG help in giving me some solutions to the problem. [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
Mike |
How to deal with Latency from Surround Mixer - Stereo Mixer. | Spyderrp7 | Pro Tools TDM Systems (Mac) | 9 | 11-02-2012 03:41 PM |
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer | Ale | Pro Tools 10 | 3 | 08-14-2012 09:05 AM |
Dithered Surround Mixer - Eating up my Chips??? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 3 | 03-25-2010 03:58 PM |
Stereo/Surround Mixer on Install | spaceman | Pro Tools TDM Systems (Mac) | 4 | 07-14-2007 09:50 AM |
Creating new stereo track in surround mixer | Keith Leary | Post - Surround - Video | 0 | 10-19-2004 04:13 AM |
