Old 06-17-2003, 03:27 PM
OgnKog OgnKog is offline
Default Installing / Booting OS X 10.2... Help needed.
Hi all,
this is a desperate cry. I've installed Mac OSX 10.2 on my G4 400 Mhz 448 Ram and it doesn't work. I've done everything that's to be done... the installation goes very well, but when it's time to boot it always hangs in a diferent place.
The thing is, i haven't seen OSX running yet after one week. [img]images/icons/frown.gif[/img]
I've tried to pull off all the RAM, all the components are the ones that came with my MAC, everything regarding hardware is OK, i even did the Firmware upgrade... but still a no no...
Any, i repeat, ANY help will be appreciated... my 6.0.2 will be home any day, now... AAARGGHH !!! [img]images/icons/frown.gif[/img]
Thanks,
Al.
We are all in this together.
Old 06-17-2003, 04:52 PM
where02190 where02190 is offline
Default Re: Installing / Booting OS X 10.2... Help needed.
Call Apple support.
Hope this is helpful.
Old 06-17-2003, 06:05 PM
guitaramundo guitaramundo is offline
try this,
-boot off the install cd then quit out of the installer and run the disc utility program also on the install disk.
try to repair permissions and verify/repair the directories.
if you can't find it it's also in the applications/utilities folder on your OSX drive.
-you might have to defrag your hard drive.
My OSX disc actually installed the OS fragmented(!!) on a clean formatted disk.....I erased the disc and did it again just to test and sure enough it was fragmented even though the OS was the only thing on the disc. weird eh? anyway I ran Norton and all was good again.
-I also recomend pulling one of your 128 Ram chips and replacing it with a 512meg. OSX is a ram hog
-make sure your OSX drive is HSF+ (extended) format.
I'm running on a G4 450 w/1gb Ram.
and PTLE can be a bit sluggish unles I repair permissions just before I start up PTLE. after that It runs tickity boo......
Old 06-17-2003, 11:05 PM
Thanks guitaramundo, i'll try the Ram thing today.
where, i've been talking to apple and all their suggestions did not help, thanks also anyway.
Al.
Old 06-18-2003, 07:32 AM
I made it!!!
I bought a 512 RAM expansion module but that didn't solve the problem.
The thing is i had bought a new HD (80 Gig) with its IDE cable... that was the problem THE IDE CABLE [img]images/icons/mad.gif[/img] . I replaced it as a last option in the last minute before throwing my Mac through the window, but... then i boot normaly and perfectly. AAAAA JAJAJAJA !!! I'm so happy !!! [img]images/icons/grin.gif[/img]
See ya,
Al.
Installing protools 8 on my new pc HELP NEEDED ANYONE :) Owdareech Productions Pro Tools M-Powered (Win) 0 12-18-2011 06:05 PM
Booting an 192 i/o aux Pro Tools TDM Systems (Mac) 4 11-16-2009 08:10 AM
Installing Plug-ins - HELP NEEDED! JackSummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-24-2008 09:50 AM
Trouble installing - advice needed Pete Gates Aspera DigiDelivery 1 11-19-2007 05:17 PM
After installing Pro Tools 5.3.1, MLCD Freezes while booting up. Affinity Music Digidesign Hardware & Software 0 06-22-2002 09:05 PM
