Old 05-18-2005, 05:31 PM
Ian Bodzasi Ian Bodzasi is offline
Default Color coding bug in 6.9???
Just installed 6.9 on a G4, running OS 10.3.8. Messing around with color coding regions and have found that if I change a region's color, then press undo, it doesn't undo. Stays the same color that I just changed it to. If I then press REDO, it changes back to original color. Basically it takes pressing undo, then redo, to undo 1 color change. Can anyone else confirm this? Went straight from 6.4 to 6.9, so not sure if this was an issue in 6.7 or not.
If it makes a difference, was using the undo/redo commands under the edit menu, not key commands.
www.bodzasi.com
Old 05-19-2005, 08:55 AM
DigiTechSupt's Avatar
Default Re: Color coding bug in 6.9???
It's working fine here. You may want to try trashing preferences files to see if that clears up the problem.
Avid Audio Tech Support
Support FAQ
Old 05-20-2005, 09:51 AM
Never mind...looks like it was a corrupt session file. Thanks for the tip though.
www.bodzasi.com
Color-coding... GW Artist Series 1 04-24-2011 11:30 PM
Color coding GS-DK Pro Tools TDM Systems (Mac) 1 06-18-2010 09:13 PM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
Color Coding Phil Ogden 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2007 08:38 AM
Color Coding Defekt Tips & Tricks 5 08-05-2007 08:47 PM
