Digi 002R & Snow Leopard compatibility issue?
Hi Guys.
Hoping someone might be able to help me out here. I've just upgraded my computer to the latest MacBook Pro and transferred all of my old info, applications etc from my old MacBook to it via Time Machine. Everything had appeared to work with no problems...until I tried to launch any of my audio applications and switch my audio output/inputs to my Digi002R. At first my computer wouldn't recognize that the 002 was there in any of my application preferences (GarageBand, ProTools LE, iTunes or in my System Sound Preferences) although the computer did recognize that it existed when I looked in About This Mac>More Info..>System Profiler. Since then I have upgraded all of my software to the latest drivers and the good news is that when I launch GarageBand as an example, the Digi002 audio option shows up under Audio Input/Output. The bad news is that when I select it to try and use it I am getting this error message: __________ Digi CoreAudio Manager cannot be opened because of a problem. Check with the developer to make sure Digi CoreAudio Manager works with this version of Mac OS X. You may need to reinstall the application. Be sure to install any available updates for the application and Mac OS X. __________ Error Details: Process: Digi CoreAudio Manager [335] Path: /Applications/Digidesign/Digi CoreAudio Manager.app/Contents/MacOS/Digi CoreAudio Manager Identifier: Digi CoreAudio Manager Version: ??? (???) Code Type: X86 (Native) Parent Process: launchd [100] Date/Time: 2010-09-26 18:29:23.585 -0700 OS Version: Mac OS X 10.6.4 (10F569) Report Version: 6 Interval Since Last Report: 929604 sec Crashes Since Last Report: 83 Per-App Crashes Since Last Report: 62 Anonymous UUID: BC824462-CC98-430C-80D9-370000BC2694 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dyld Error Message: Library not loaded: @executable_path/../Frameworks/DFW.framework/Versions/A/DFW Referenced from: /Library/Frameworks/DHS.framework/Versions/A/DHS Reason: Incompatible library version: DHS requires version 8.0.3 or later, but DFW provides version 8.0.1 Model: MacBookPro7,1, BootROM MBP71.0039.B05, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.62f6 Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.16.1) Bluetooth: Version 2.3.7f1, 2 service, 19 devices, 1 incoming serial ports Network Service: AirPort, AirPort, en1 Serial ATA Device: Hitachi HTS545025B9SA02, 232.89 GB Serial ATA Device: MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-898 USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26100000 USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24600000 USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x06500000 USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0236, 0x06300000 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06600000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06610000 FireWire Device: d2 quadra (button), LaCie, Up to 400 Mb/sec FireWire Device: Digi 002Rack, Digidesign, Up to 400 Mb/sec I have upgrade all of the software (as below) so I am wondering if the problem is that the Digi 002R is not being supported by Digidesign and/or Snow Leopard now. Mac OSX 10.6.4 ProTools Le 8.0.1 Digi CoreAudio Manager 8.0.3 Can anybody shed a little light for me here at all? Do I need to upgrade my hardware if I want to use it with Snow Leopard? Thanks in advance for taking a minute. Cheers, Dave |
Re: Digi 002R & Snow Leopard compatibility issue?
I couple of things wrong here. First, are you installing Pro Tools AND the standalone Core Audio driver? It appear so from your post:
Second - you need Pro Tools 8.0.3 or higher for compatibility with Snow Leopard. I would recommend a clean uninstall, restart and install Pro Tools 8.0.3 or higher (8.0.4 is the current version), making sure the box for Core Audio Driver is checked during installation. |
This is my first post on this forum. So hello everybody! I hope you guys can help me with my problem. Like ruralrecords I've got the same connection problem with my DIGI002r. The difference is, I don't have any error messages. Also 2 days ago it was working fine on an iMac (early 2009) with OSX 10.5.8. I run OSX 10.6.5 / PT 8.0.4 on a Mac Pro Quad (late 2009) When connect the firewire (800<->400-cable) from the mac to the 002r the 1394 Backpanel-Link-LED shows connection. (All connected with power off and power on by first the 002r and second the mac) I did a clean un-install en re-install Protools 8.0.4. After a restart I try to open protools but I will not recognized the hardware. Also iTunes, Quicktime or other audio apps don't open the CoreAudio Manager Another weird problem will appear when the 002r is connected and OSX startup fine, all the external HardDrives (firewire) will not be recognized. (no Disks in Disk Utility). External Drives will only be recognized when shut down the mac, disconnect the 002r and restart OSX. (Then they show up in Disk Utility and finder) I think the problem is somewhere between the 002r and the CoreAudio Manager. I don't know if the 002r (firewire port on the 002r) or the CoreAudio Manager (in OSX 10.6.5) is the problem. Even the 800<->400-cable is tested and ok! I Hope someone can help me? OneMoreThing: Will this problem be solved with the protools 9 software (with better CoreAudio Manager Drivers)? Regards, Iwan |
Digi002r is working on OSX leopard 10.5.8 tested on a mac mini with firewire 800<->400-cable.
Is their someone working with a digi002r on OSX 10.6.4/5 running PT9? |
Only 003 on 10.6.3 PT9, works great
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
I use an 002r on 10.6.5 just fine, using a 2008 Mac Pro 8x2.8ghz. Worked great with 8.0.x and works fine with PT9 as well. Note however that I NEVER install the CoreAudio drivers, I avoid them like the plague.
@Slim thnx!
The connection problem also is solved in Snow Leopard (10.6.5) First we reconnect the 002r on the iMac (running Leopard 10.5.8) it was running on and try to open protools. This was actually working! Back to my MacPro and try to open protools again, ta-ta it's working! I really don't know what happened but it's working fine. |
Pro Tools 11/Snow Leopard Compatibility Issue? | cariprez | Pro Tools 11 | 5 | 07-10-2013 10:51 PM |
Snow Leopard 003 Digi CoreAudio issue | MyGunCleaningHat | General Discussion | 4 | 01-13-2011 11:39 AM |
Digi 002 rack..PT8.0.3.Snow Leopard Compatability issue | delta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-01-2010 01:35 PM |
Native Instruments Akoustik & Elektrik Piano Compatibility on Leopard & Snow Leopard | DigiTechSupt | Virtual Instruments | 0 | 01-07-2010 11:08 AM |
OS 10.6x (Snow Leopard) compatibility | Euca Design Center | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-02-2009 02:02 PM |
