Digital Out 002 - change channel
Is it possible to change the default digital channel in ( which is 17 & 18 ) to any channel you want too on the 002 control surface- if so how - thanks ronan in ireland
Re: Digital Out 002 - change channel
Not sure if I understand the question. SPDIF in only comes in via "channels" 17&18, but those can show up anywhere on the control surface as any track can be moved. If you are trying to put that track say, next to the drum tracks; just go to the mix window and drag&drop it where-ever you want it. This can be done from the edit window as well, but the mix window shows it better. You can drag any channel to any slider.
Strike! - unexpected MIDI channel change | edgarbc1 | Virtual Instruments | 2 | 02-03-2009 03:19 PM |
Can you change the default channel order of an interleaved.. | dj_grimmace | Post - Surround - Video | 4 | 11-12-2007 08:10 AM |
Change a MIDI input channel for Strike | WRETAUDIO | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-02-2007 05:33 AM |
Primary IDE channel using PIO can't change to DMA? | iroc/pt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-16-2005 06:00 PM |
Change Output channel for selected tracks *DELETED* | Micah777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-15-2004 01:43 PM |
